I've checked my ground and it goes to zero ohms across the bc ground wire so I know I have a good ground, but it seemed to almost force lock/unlock when I had it ground to the throttle bracket. The brake circuit also goes on off with a test light and I'm sure I have the correct pins tapped at the tcm. The led light will light up blue brightly in neutral but when you press lock or unlock it will light up green or red for less that half a second and almost feel like it going to lock but then the light just goes really dim and the buttons don't respond. When I first installed it it worked one or twice when I forced locked it, but it did not work long. I'm getting accelerator position codes which probably means I have a bad ground connection but I am tapped into the same bcm pink and black/white wires it says to use in the instructions. Once it shifts to fifth at cruise with the tc locked it will also not unlock our downshift even at WOT, but it will in tow haul.
I'm also assuming that I can ignore all the part about the steering wheel controls and just leave the green wire alone. I also have a insulated silver strand of wires just sitting the next to the green wire in the big grey insulated cable going to the tcm? The instructions seemed like you could just add a toggle switch to the pink 12 volt wire and your steering wheel controls would lock with the switch on which doesn't seem right as there would be absolutely no connection to the steering wheel?
I don't even care about the steering wheel controls but just wish I could make this thing workwmight sound stupid but what if I just hooked the pink and ground to a12 volt battery or maybe 2 6 volts in series and run the ground to the battery also?
