wow!
If you can switch cams 6 times in 2 days you must have Wade helping!!!! You are a BAD MAN! Jeff
I have graphs, ill try to get you copies one way or another here. Keep on me...Is there any graphs available for customers? I'm doing another engine and I'd like to make an informed choice, not a Wade-o-Meter or Hood Lift indicator decision.Specifically looking for max area between 2500-4500.
I assume tony's testing was on an engine dyno, not a chassis dyno therefore swapping cams would be much easier?
I dont know who Wade is but i did have Mark helping me. To set the DYNO up for my motor, get it up and running, six cam swaps, four turbo swaps and injector swaps in two days made us very very tired. Even on an engine DYNO.If you can switch cams 6 times in 2 days you must have Wade helping!!!! You are a BAD MAN! Jeff
Like i said, just cause this cam worked better for me, doesnt mean it will for others. Im not saying cam A is better than cam B, they both got the job done for me. But its defenatly not something to be overlooked, or rushed into a decision.
Ok... I got it now... I just read the whole steel piston thread... LOLIf you can switch cams 6 times in 2 days you must have Wade helping!!!! You are a BAD MAN! Jeff
