Rattle bomb
Its rattle bomb, but it turned out pretty good.....:woott:
powder coated or rattle can love the colors:thumb:
Well the motor is in the truck, just have to finish a couple little things. It should be running tomorrow and back on the dyno Friday to possibly set a new VGT record single charged.....On a side note, I disassembled my block that came outta my truck and the rods are straight, the pistons look brand new, which means a 650 hp stock bottom end will last if you have great tuning and use some sense. It was at that power level for 2.5 years with over 100 passes at the dragstrip and daily driven...:thumb::woott:
What turbo and fuel mods were you running to make that power for that amount of time?
For two years, I was running a 68MM stage 2 and 45 overs with a modded LBZ pump, I changed to a 72MM Novemeber of 2011, and then I put 100 overs in the truck Novemeber of this year.
Awesome man! Good to know. Have been debating on either running a 475 over stock or one of Mark's 72's. Either setup will be accompanied with 40-50 overs, 2nd cp3.
I like the way the big single drives, and mark will probably say the samething.
