Brake upgrades (stock replacement)
clrussell
pro-procrastinator
Sep 23, 2013
5,912
375
The lbz is about due for new brakes, I have zero complaints with the stock system and will go back to the same unless it’s worth it.
Are the stock replacement options worth the extra $? I’ll eventually be stepping up to 37s.
Drilled and slotted rotors, and better pads such as ebc. Not debating ceramic vs organic. Also is the life span as good as oe?
lutzjk913
1,590
108
groveport, ohio
I’m OEM all the way here Corbin.
my stock fronts have 135k on them with over half pad left
rears went around 80k due to a stuck caliper slide
1,778
I think you want the orange pads or OEM. OEM will last the longest. Also, I wouldn't run drilled rotors on our trucks. Crack too easy
monster50iii
329
Another thing you can do while you do brakes, is suck your reservoir almost dry. Get all the old fluid out. Refill, and bleed each corner to get all the old fluid out. Brake fluid attracts moisture, which gives you a softer pedal.
clrussell
pro-procrastinator
Sep 23, 2013
5,912
375
good point, I have a brake flush machine so it’ll get this treatment when it gets new brakes.
clrussell
pro-procrastinator
Sep 23, 2013
5,912
375
ive always went straight oe when I’ve done my previous trucks.It’s never been an issue. And mileage is insane on these trucks brakes unless towing constantly
1,623
NP. This section really should be called "brakes and suspension". As for brakes, just use quality parts. Id probably shy away from drilled/slotted for a daily.
5,037
@gmduramax was just talking to me about doing this on my old truck.
i wouldnt do drilled rotors but slotted would be ok. Drilled makes them crack. Then add either hawk or EBC severe pads and should make a difference. if you want the same life span, id keep stock stuff. The other pads will wear much quicker and be dirtier.
Updated 😁
Dozerboy
4,826
402
TX of course
zakkb787
<that’s not me...
Sep 29, 2014
2,340
52
Granite Falls NC
Man, I put Raybestos Element3 pads and rotors on my truck over the summer and they are amazing. Best brakes I’ve ever had on any of my trucks. Not expensive and they look great with the coating too. The pads are a hybrid.
3,918
1,076
Neenah, Wisconsin
I agree with others, drilled rotors are not great on these trucks if your goal is longevity. My truck has EBC slotted/dimpled GD3 rotors and their orange pads and you'd think it stops like a Corvette, especially once I added the LML hydroboost. I cannot comment on lifespan as the truck spun a main not shortly after and has been sitting since. I'm hoping to get it out and finished here shortly (hoping late April/early May).
