Aluminum Radiators?
4,829
1,873
Radiator with leaking tank at seam
Pry with screwdriver to open the little tabs
After screwdriver, you can carefully open them a little more with some pliers
Screwdriver again to pop the tanks off
Tank removed
Carefully remove the gasket and save it
Wash and clean everything. Opportunity to clean out the inside of the radiator channels
Thoroughly clean out the channel where the gasket sits and apply ATV or whatever the strongest version you can find
Put the gasket in and apply another bead of ATV
Put the tanks back on and bend the tabs back down tight
Enjoy a leak free radiator
Only works if the plastic is not cracked and is only leaking at the interface between the aluminum and plastic. Allow for sufficient time for the ATV to cure properly before refilling radiator
Please excuse the ignorance, ATV sealant?
WVRigrat05
ISO Duramax
Jan 1, 2011
3,129
French Creek, West Virginia
I'll have to try this. The OEM radiator did it at 60k. Replaced with an AC Delco from rock auto, started again at 80k ish, ran til 115k, put on a dorman, it made it until 140k. Put ARP studs etc, new OEM coolant tank and cap and a TYC radiator. It has 170k now and is leaking again. I've ran extended life orange stuff, been running Dex cool since the engine upgrade/rebuild, and same shit different summer. It has a 190 degree thermostat, verified with temp gun and hot water before installing. I've ran mitsimoto 180's, updated GM OEM, drilled out GM OEM, drilled out mitsimoto (saved my butt because it stuck closed) and now I'm running a whatever American trucks sells that's a 190. Keeps pressures down but still swelling the tank.
Did I mention I do still drive hard?
3,498
If you guys are getting that much flex in your core support/radiator area to destroy radiators, have you all been checking your body and motor mounts for breakage/wear??? Something is over-torquing that support.
I was still on the original radiator in BBT at 229,000 miles when I sold her.
3,111
Some people just break stuff....
1,656
What about your oil cooler?
