Aluminum Radiators?
Bdsankey
4,827
1,871
Larsen, Wisconsin
Radiator with leaking tank at seam
Pry with screwdriver to open the little tabs
After screwdriver, you can carefully open them a little more with some pliers
Screwdriver again to pop the tanks off
Tank removed
Carefully remove the gasket and save it
Wash and clean everything. Opportunity to clean out the inside of the radiator channels
Thoroughly clean out the channel where the gasket sits and apply ATV or whatever the strongest version you can find
Put the gasket in and apply another bead of ATV
Put the tanks back on and bend the tabs back down tight
Enjoy a leak free radiator
Only works if the plastic is not cracked and is only leaking at the interface between the aluminum and plastic. Allow for sufficient time for the ATV to cure properly before refilling radiator
Please excuse the ignorance, ATV sealant?
