Alternate firing order tuning
Mikey
Drag Racer
Jun 13, 2009
560
Is alternate firing order tuning available without the need of a harness or pin swap?
Harbin_22
3,858
7
Southern Indiana
Lol. It takes all of 2 min to repin and never have to think about it again. To each their own but repinning seems way more fool proof to me. If you can build a motor, you can swap a couple wires
PACougar
2,105
40
El Dorado Hills, Ca
I didn't want to sound like a dick:hug:, I had the same thought. Why lock yourself into 1 tuner.
S Phinney
4,011
Quncy, Fl
It is much simply to repin especially considering a tuning use that could be related. GM products already have enough errant electrical problems to complicate another possible issue.
carpenca
Dec 17, 2010
168
Brayden Fleece gave Guy @ SoCal the base files for the alternate firing order cams. You should be able to contact them (SoCal Diesel), and then send the base file to whatever tuner you wish. :thumb:
Caleb
Mikey
Drag Racer
Jun 13, 2009
560
Caleb
I like
I haven't done the pins before so throw doing them in "2 minutes" out the window
I would like to learn and seems similar to when I did my dsp5 install.
I'm a ways out from doing all that so we will see how this thread will influence my decision when it comes time.
Thanks everyone for the input
Mikey
Drag Racer
Jun 13, 2009
560
I would hate to lock myself into 1 tuner also and thanks for the heads up, but don't the tuners lock you in whether your going with AF firing order or not?
Is there a trustworthy tuner out there that will write tunes that I can later modify?
Thanks!:thumb:
13,605
639
Thanks!:thumb:
That's not what he was saying. He was saying, if you don't modify the harness, you have a choice of either Fleece or Kory to do the tuning because they are the only ones changing the firing order in the ECM, but that has since been corrected because we now know Guy has the base tune files available to be used by any tuner you choose.
PACougar
2,105
40
El Dorado Hills, Ca
That's great to know Josh, I hadn't heard that.
clrussell
pro-procrastinator
Sep 23, 2013
5,912
375
I like
If you can install a dsp5 switch you can re pin the harness. Pretty much same concept other than you have to pull a pin out not just stick one in.
Mikey
Drag Racer
Jun 13, 2009
560
Ok thanks
But can I make minor tuning changes to fleece or Kory's tunes?
