Any more updates?
I don't know if this is the best comparison as the CT6 isn't making ~910ft-lbs of torque, towing 20k+ lbs, and also doesn't weigh 7-8k empty. They may be similar internally (I cannot comment on this as I don't know) but the use case is far different.I don't know... The bone stock 10L90 in my CT6, which as far as I know is almost the same as the 10L1000 'Allison', clicks off shifts absolutely beautifully. Orders of magnitude better than the 6L that was in the CTS I had before this.
Sent from my Pixel 5 using Tapatalk
ive heard mixed reviews. i feel the 6 speed in stock form (engine and trans) is stronger. alot of it stems down to the fact there is so much more shifting going on (VB parts will wear faster) and the lack of pressures/clutches in needed areas. this VB kit will make a stock trans last faaaaar longer though with a truck in stock form.How reliable are these new 10 speed Allisons at stock power, anyone know? Just curious..
What makes you think the engine is stronger, are you meaning as far as durability? I thought the l5p was a beast compared to the previous generation duramaxesive heard mixed reviews. i feel the 6 speed in stock form (engine and trans) is stronger. alot of it stems down to the fact there is so much more shifting going on (VB parts will wear faster) and the lack of pressures/clutches in needed areas. this VB kit will make a stock trans last faaaaar longer though with a truck in stock form.
i was more refering to the fact that if the engine and trans are kept stock, the stock 6 speed holds up better over time. now theres guys that can break an anvil that im sure have killed stock 6 speeds in a stock truck but you get the picture.What makes you think the engine is stronger, are you meaning as far as durability? I thought the l5p was a beast compared to the previous generation duramaxes
