LBZ injector # 97361355 list $504.10 net $378.07 $100.00 core each
Revised fuel system with new injectors
For 2006, the injector tips have been rotated approximately 35 degrees compared to those on the previous injectors. This re-orientation points one of the seven spray holes directly toward the glow plug, improving the Duramax 6600’s cold-start performance
Each state-of-the-art high-pressure injector has its own solenoid to manage fuel spray, with seven spray points in each injector tip for better fuel vaporization.
LLM injector # 98002368 list $779.12 net $545.39 $100.00 core each
FUEL INJECTORS IMPROVE COMBUSTION CHARACTERISTICS
Sophisticated solenoid injectors are used to precisely control combustion and to take advantage of the cleaner Ultra Low Sulfur fuel federally mandated to be available for all on-road diesel vehicles beginning in the 2007 model year. The injectors have six specially shaped holes, developed by Powertrain engineers to better atomize fuel for complete combustion of the fuel. The injectors are programmed to inject fuel into the combustion chamber at multiple intervals during one compression stroke. By doing this, the combustion event can be tailored to lower emissions and reduce noise at its source.
