2015 6.2L 8L90 no 3-4 shift after Sonnax kit
WVRigrat05
Wound for sound
Jan 1, 2011
3,124
26
French Creek, West Virginia
So back story to this issue, I pulled the valve body as a PM job and to also change out the solenoid harness for a temp sensor issue.
I installed both Sonnax Zip kits, a new GM internal harness (Matched the old one to a T) truck initially went straight to neutral when I shifted to 4th, so pulled it apart, thought I addressed the issue....
Now when it shifts to 4th it defuels and tries to shift and just surges with fueling as it's trying to shift but will not go into neutral like the famous 3-4 neutral shift describes. It's been at the dealership 3 weeks they've maybe spent two hours on it, getting upset.
what am I missing? Do I just need to risk an eBay reman or bite the bullet on a 2,700 dollar valve body from next gen diesel?
Thanks for any help guys, trucks been down a month, any ideas would be great, I'm to the point of a valve body or hauling the truck to big dipper for a build if he'll touch it not running correctly
kidturbo
Piston Tester
Jul 21, 2010
2,777
1,768
Somewhere On The Ohio
www.marinemods.us
Sounds to me like the valve body. If you have EFIlive, HPT, or a SnapOn tool, you can engage each clutch manually to verify what's happening. Would verify all the solenoids are activating manually, up on the rack. Maybe find a used valvebody to snap in for a test drive.
WVRigrat05
Wound for sound
Jan 1, 2011
3,124
26
Dealership finally got a hold of me after messing with it today, said solenoid 8 is stuck open, said they could replace the solenoid for 2,700 bucks but may not fix it, so anyone have a good known source where to buy a used or reman valve body so I can get this thing going?
WVRigrat05
Wound for sound
Jan 1, 2011
3,124
26
I ordered a reman valve body, just for the simple fact if it doesn't fix it I'm not out 2,700 on an old transmission. I've got plans for this truck next year, just trying to keep it reliable until then
WVRigrat05
Wound for sound
Jan 1, 2011
3,124
26
I'm at least going back in the motor for a larger cam and get the trans built, still on the fence on a charger or not. I did the 59 LPM?? GM injectors, head work, ARP studs, LS7 lifter, Texas Speed AFM delete, cam, GM timing set and cam phaser, GM oil pump, oil cooler lines and radiator this past spring
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,886
801
Central OH
Which LS7 lifters? My buddy did his Tahoe 50k miles ago and his LS7 lifters from GM are bleeding off / ticking already. Replacement Delphi LS7 from BTR don't look promising either, he took the new ones apart before install and it was sad to say the least
WVRigrat05
Wound for sound
Jan 1, 2011
3,124
26
I did the Delphi LS7 lifters. I've heard horror stories on them like this AFTER I got the truck done, I'm gonna go with a set of performance lifters when it's apart next time, along with larger valve springs and some sort of high end trunnions, just did a GM set last time
3,422
BTR-V2 or CHE for trunions. No opinion on lifters other than stay away from Morel (failures) and use OEM trays whenever possible.
The C5 Corvette guys area always talking abut these things.....
WVRigrat05
Wound for sound
Jan 1, 2011
3,124
26
Tom, I used GM everything as always other than the Texas Speed AFM delete kit and the Texas Speed cam and even the AFM kit has the option of their stuff or GM and of coarse the ARP head studs and stainless ARP manifold bolts.
WVRigrat05
Wound for sound
Jan 1, 2011
3,124
26
I was ready to get back in a Duramax shortly but I'm almost 1,500 in on this thing again with tow bills included and I just bought a 2013 90k mile Audi for a spare DD/work car and I'll be damned if it doesn't have a piston slapping (don't hear it unless you revv on it like a HS kid of coarse) so I'm another 6k+ out on it and now getting ready to have a motor put in it
WVRigrat05
Wound for sound
Jan 1, 2011
3,124
26
I got a good enough deal on it to deal with it, I just didn't anticipate being over 15k in on vehicle repairs and appliance upgrades in the last two months lol, that's how it goes though
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,516
590
At Da Beach
My wife’s car blew up on me last month 1.8 miles from the dealership where I was trading it in for her new ride. I feel your pain.
WVRigrat05
Wound for sound
Jan 1, 2011
3,124
26
Damn dude that sucks. So my valve body finally shipped Friday, says it'll be here Tuesday, conveniently... I have to go back to work Tuesday night so I'm gonna drive back back in Wednesday morning and take it to the dealership and hopefully they get the damn thing running next week.
WVRigrat05
Wound for sound
Jan 1, 2011
3,124
26
Glad to see you guys are still on here and doing well, time has flown by. I called Mike L's cell phone a few weeks ago and found out he passed away and Evan is running that place now, hated to hear that
