SDP also makes a 2 piece design. It enters from the top.I was trying to find the HSP one but no luck.
Catch can is about all you can do. Unfortunately that is one reason most guys avoid billet valve covers, they look cool but then force you to spend hundreds more to cure a massive design flaw.Ive got a set of PPEI valve covers on this thing. They are non-baffeled, and right now just have female npt thread. I need to do something for crank case vent, What is the common thing to do with after market covers? Is a catch can an option i should look at?
That’s about what I have in my shopping cart besides that mine only have one -10 port in the centre of them. Looks like you’ve got two cans mounted there with two inlets each?Well I wrote it all up real nice, then closed page by accident. My suggestions
1. Leave the deflectors on rocker rails, and bend up if need to better cover hole and knock down splashing oil from getting blown out.
2. Big catch can openings is most important. Trying to slow down the air speed is goal. I add SS scubbies in the cans for added surface area.
3. Drain back to factory check ball return on the LML front cover.
I screwed up and went with with 2 10AN, then doubled it to 4x 10AN and dual cans. Routing the lines high up also helps. But in the end, if you blow a piston, it's all coming out those two holes in about 3 seconds anyways..
Here is my best effort with custom venting.
Thank you i appreciate that very muchJake, gotta hand it to you.....you did a nice job!
Yes ecm and wiring all changed over to Lmm.Did you change the ecm? I'm just spitballing but I'd say you've got an issue running regular solenoids on a setup that had piezo injectors
You know I've never checked myself but I know we have a fuel cooler on these trucks for a reason. I wouldn't be surprised if the fuel wasn't over a 100° being returned. I know one of our members did some experiments a long time ago with better fuel coolers. If I remember correctly with a thermal camera they said the fuel in the diesel tank was getting heated from the hot return fuel.Yes ecm and wiring all changed over to Lmm.
Maybe I’m being paranoid, it does run better now with the current injectors. Quick google tells me return fuel temp does run around 100 degrees. Maybe it’s just something I never payed attention to before?
