2012 Low End Knock
Immokalee
Apr 10, 2025
Florida
I recently replaced a 2011 LML in a 2500hd with a 2012 LML out of a Cab & Chasis. After the shop getting it in a running, I went to pick it up. When I took it for a test drive I noticed a slight knock. I had the shop check it and they verified that there is a slight knock in the low end. It is slight to the point that most think it is just a normal diesel sound, but since it sounds the same as the start of the problem of the one that blew I can hear it. Is it possible that the 2011 ECU could cause the knock in the 2012 motor? The ECU was deleted and tuned prior to me purchasing the truck so I don't know what type of file they flashed, but the shop said it was putting out about 50 boost and suggested having it defaulted to OEM. Once that was done it is throwing the codes for the missing sensors, so now I have purchased a tuner to remove them and get it out of limp mode.
Any idea what might be causing the knock and a way to fix it? Any help would be appreciated since I am out almost $16,000 and still have no truck.
3,148
Could be rod knock. Could be injector knock. Could be timing knock. None of us can here it so we have no way of knowing
Did the shop supply the engine or you? If the former then make sure they get it taken car of. If you then it's going to take more money to fix, that is, if it even is a knock
13,882
993
I would try doing a fuel quantity reset with a scan tool and see if that clears it up.
