tl;dr I was drag racing my 2003 Denali with an old Maggie and on the 3rd pass of the day, it dropped oil pressure during 2nd gear. Normally holds 70 PSI above 4000 RPM, but it dropped to 50 PSI for the rest of the run. Normal hot idle is 30 PSI, now is 6-7 PSI.
So, taking all bets: what happened?
The long version is I picked up this 2003 Yukon XL Denali a year ago with a very early (casting date of 2002) Magnuson supercharger installed on it. Previous owner clearly cared for it at one point, but abused it the last couple years. Radiator was cracked (and full of stop leak), everything except the rear main seal was leaking BADLY, and the engine had clearly been run out of oil more than once. Cam was trashed, lifters were trashed, cam bearings are... not great. Exhaust valves were pitted, spark plugs had no electrodes left (not sure how this even ran TBH).
I decided to do a sloppy-mechanics style "repair" on it and see how it went. I pulled the heads off, lapped the valves, new valve stem seals. New Mahle MS16124 headgasket and GS33380 headbolts, back on they go. Swapped to a LS9 cam, new LS7 lifters, PAC-1218 valve springs. All new seals everywhere to stop the ridiculous oil leak rate.
Popped off a main cap, and the main bearings are freaking mint. Looks brand new. Crank thrust is well in spec. No play in rods either, so I buttoned the bottom end back up. Yay main-priority oiling, I guess.
Existing oil pressure senor was bad (as is common on these Gen3 LS motors) so I put in a brand new GM 12677836.
Oh right, the cam bearings are still trash, and changing them without pulling the engine sucks. ? I know, install a Melling 10296 high-flow oil pump! Surprisingly, this seemed to work, as oil pressure was awesome, until it wasn't halfway down the track today while dialing in the tune.
This is a little over 2,000 miles after the "rebuild". Blower is making 7.0 PSI, AFR according to a wideband was 11.0:1 for every pass, so not leaning out. I would see 1-2° KR right at the start of each run but decay to 0 halfway through 1st gear, probably false/burst knock, as I was only running 8-10° total advance. I am spinning it a bit faster than stock. The last pass was shifting at 6,600 RPM, but the first two shifted at 6,800 RPM. It starts to choke on the stock exhaust up there (stock redline was 5,900 RPM) but the cam should otherwise flow north of 7,000 RPM.
Once I get some time, I will verify the oil pressure is actually low (not just another sensor failure), and if so, start tearing into it and see what happened. But I am curious on your guys bets and thoughts.
Edit: best pass was a blistering 14.991 @ 90.89 MPH ?
