The New 17" PYOs from WCfab
3,150
I got some stripped out threads on some of mine. Had to take one off to keep from loosing it on the road
Cougar281
1,980
406
St Louis, MO
Why must I be a stickler for OEM parts? I retrofit TPMS into my 2003 and I know the 15114379 sensor works, but mine are now 10-11 years old so I want new ones. I have ordered 4 sets so far, with a 5th set on the way, and only 3 of the new sensors weren't 7+ years old.
They appear to manufacture these in batches, and I have seen a ton of sensors dated September 2019 and a handful of April 2022. Going to try and get 2 more of the April 2022 batch and roll with those, so cross your fingers the incoming order is fairly fresh.
Or I should just do the sane thing and put generic sensors in, no reason they shouldn't work fine. But I'm apparently too OCD for that
On the plus side, I did manage to find a set of new-old-stock 9597170 GMC hubcaps, so this should look awesome when it finally gets installed.
I had some strange things happen with OE sensors (or they were supposed to be OR). Had a set installed and nothing. Wouldn't trigger at all. Got them replaced and before having them installed, I tested them. They triggered fine, I paired them to the truck and they functioned as expected (showed 0pso). Had them installed and gone. '--' in the DIC, wouldn't trigger. Through trial and error, I discovered that they would trigger if I used some other vehicle profiles, but no 2004-2007 gm truck. Got a set of Autel MX sensors, programmed them, had them installed and haven't had an issue since.
3,796
423
I need to wash the truck and put a new windshield in it (both scheduled for Friday), but I got impatient and had the new tires put on today. Here's a little teaser until I can get some glamor shots this weekend.
The new setup next to my Suburban (stock wheels & tires) for size comparison:
An intentionally bad angle to tease you all:
3,796
423
Here you go you ravenous animals LOL
The paint cleans up OK for a 23 year old truck, but don't look too close 😬
dmax_ty
479
37
Utah
Looks awesome man. I think 17-18” rims look the best on the GMT800 (mounted on 33s). Very proportional. Sucks now a days because of the bro truck scene. 17” and 18” are tough to find.
The Wherli PY0s look sweet…I may need to splurge on a set.
