The New 17" PYOs from WCfab
DuramaxRamRod
170
23
MI
lutzjk
1,922
376
groveport, ohio
Still have my original set.
They were plastic dipped forever. Going to start stripping them down and going to polish them they might got back in the truck one day
3,546
My original set of PY0s still has their Toyo Proxes on them from the BBT racing days, bolted to the half-ton chassis in the garage. (Yes, I converted it to 8-lug)
1,664
Some one was asking me about the tapper on the 1500 stuff Vs the 2500 stuff. Not sure if you documented it But IIRC the 2500 knuckles bolted on but the tapper was cut deeper on the 2500 knuckles so you had to put a washer under the castle nut so the threads don't bottom out on the ball joints. And I think you just swap the 2500 outer Tie rods over.
3,546
I found tapered adapters for the 2500 upper ball joint size difference. Worked like a charm.
Lower ball joint was same diameter.
I also found that early 99-00 2500 knuckles had a smaller diameter 1500-size tie rod hole.
1,664
Cool thanks!!
3,790
394
OK, got the measurements I wanted, and hopefully the measurements y'all wanted too!
I have been running stock Hummer H2 rims with BFGoodrich All-Terrain T/A KO2 tires in 315/70R17 (~35" x 12.5"). With the H2 rims, there is only minimal trimming of the lower plastic bumper and some "massaging" of the cab seams to fit. My hope here was these WCFab PYO rims would match the stock H2 rims for width and backspacing.
So not to bury the lede: the WCFab PY0 rims are identical to the factory Hummer H2 rims in terms of diameter, width, and backspacing!! This is exactly what I was hoping for, though WCFab would not confirm it. But I can confirm!
I compared the new WCFab PYO, the Hummer H2, and the stock PY0 rims:
Those polished + chromed GM PY0 rims somewhat steal the thunder of the polished aluminum WCFab PYO. However, I think the stock finish looks good, and plan to run them as-is, at least for a while.
Not that anyone but me is likely to care, but all 3 rims appear to work with the stock GM 15114379 TPMS sensor (and therefore probably any TPMS sensor). I've been running that sensor in the H2 rims for 10 years now, and plan to put new ones in the WCFab PYO when I get the new tires in.
The WCFab PYO are labeled "SAE J2530 RATED 3200 LBS" which is a bit below the rating of the new BFGoodrich KO3 tire (load index 128 = 3968 lbs).
It does beat the load rating of my old KO2 (load index 121 = 3197 lbs), so at least I won't be losing capacity with the new setup, though I don't really gain any either.
WheelWeight (lb)Diameter (in)Width (in)Backspacing (in)
Stock GM PY017.1166.54.9375 (4 15/16)
WCFab PYO23.1178.55.59375 (5 19/32)
Hummer H233.2178.55.59375 (5 19/32)
So the WCFab PYO is 10.1 lbs lighter than the Hummer H2 rims! I am impressed. And lucky, because the new BFG KO3 is fat AF, more than eating up the weight savings from the rim swap. Dangit BFGoodrich!
Tire / ComboWeight (lb)
BFGoodrich KO2 (10 years old, 56k miles, 3/32" tread left)58.5
BFGoodrich KO3 (per their website)69.5 (+11.0 lb, +19%)
BFG KO2 on Hummer H291.7
BFG KO3 on WCFab PYO92.6 (+0.9 lb, +1%)
If you want to see the full set of photos of my measurements, they are here: https://immich.reaperlegion.net/s/WCFab-PYO-comparison
That's just the measurements, I'll get some glamor shots once I get the new tires in and mount them on my truck.
3,790
394
@DAVe3283 Are you running the 35s with keys cranked?
No, I've got the torsion keys set to the stock position. The GMC front end is more forgiving than the Chevy in terms of large tires from what I've seen, and keeping the torsion keys at stock means I don't grenade CVs when racing and the ride quality is still good.
Sent from my CPH2655 using Tapatalk
N2BRK
2,393
733
arguably not as handsome, but the LMM had a factory 17” wheel. I think a hair narrower and similar weight to the WCFab wheel.
3,790
394
Why must I be a stickler for OEM parts? I retrofit TPMS into my 2003 and I know the 15114379 sensor works, but mine are now 10-11 years old so I want new ones. I have ordered 4 sets so far, with a 5th set on the way, and only 3 of the new sensors weren't 7+ years old.
They appear to manufacture these in batches, and I have seen a ton of sensors dated September 2019 and a handful of April 2022. Going to try and get 2 more of the April 2022 batch and roll with those, so cross your fingers the incoming order is fairly fresh.
Or I should just do the sane thing and put generic sensors in, no reason they shouldn't work fine. But I'm apparently too OCD for that 😐
On the plus side, I did manage to find a set of new-old-stock 9597170 GMC hubcaps, so this should look awesome when it finally gets installed.
