Oct 12, 2012
102
Coatesville PA
What are the mods on your truck? What size tires and wheels+offset?
As of now 20% injectors, fast 150, turbo horn ported, Efi live by starlite , turbo back to single stack, afe intake, as far as performance.
Very shortly headed to Evan for a built trans, buying a S400 type turbo kit here shortly once my research is done.
Wheels are 20x12 -44 offset 33x12.5R20's on gear alloy big blocks
aldenrichie
106
Covington, TN
Swapped out original scratched/peeling taillights for some new ones.
And a night picture with the running lights on
Sent from my SM-N910P using Tapatalk
aldenrichie
106
Covington, TN
Indeed. They're "spyder" brand. I had been looking for a set with the led-bar like these to compliment my headlights for months. Finally ran across them on ebay a week or so ago.
frankenstien
587
Fairbanks,Alaska
Went to change a burnt out blinker bulb on the IPC, the batt gauge needle was stuck on the stepper motor bad, pulled the stepper motor off the board,
Driving like this until i get my stepper motors in the mail
1,514
Oil change, greased suspension, adjusted brakes in the Crossman.
Trying some delo LE 400 5W-40 synthetic.. Walmart had it gallon for $18.00 vs Dino le400 is$12.00 Mobil 1 syn was $27.00 gallon..
See if there's a difference..
met up with/helped out a fellow hotshot guy, kowclub173, got his lower rad hose swapped out.. I was more the tool bitch then wrenching, BS's business plans and equipment setup, safe travels man!
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
You will get tired of washing it eventually. Lol
Never!
Especially on days like today, in the PNW!
:D
3,796
423
Put a lift gate on the truck! Forgot to take a photo when it was done, so here it is with just the frame mounted.
On the way back to Idaho, my heater core started leaking. :( So there goes at least one weekend. I'll bypass it for a couple weeks until I have the time to tackle it.
minerigger
2,660
Casper, WY
I'd tell ya that heater season is over but it's 40 here today so can't make that claim yet. Good looking truck, really like that blue
03greendmax
Mar 21, 2016
LB7 to lly
Just pick this 2003 Chevy lb7 truck up had no engine nor transmission paid $1000 for it found a 2005 lly engine and transmission just got her back on the road!! Love it!! Fist time owning a Chevy Duramax.:thumb:
