motoking_1990
1,957
Terre Haute, IN
Well I'm trying to get one. Also need some optilube. Trying to figure out what they do with the factory pickup on the top of the tank so it's not open?
I just left mine open. Just more ventilation. Not much can get up there unless you have it in that deep of water or mud. Have heard of people running their lift pump return to it. You could always put one of them rubber vacuum caps on there.
pnw_lml
Apr 26, 2016
10
I found out why my truck has been running like sh*t. It's been cutting out when I apply throttle. The only thing that changed was installing an efi live tune from motorops. After a trip to the dealership (who found nothing) I called a local diesel shop and they suggested I call motorops again and find out if I was sent deleted tunes instead of the non deleted tunes I ordered. thanks now I have to delete or figure out how to run efi live from my laptop and follow 25 "easy" steps (hope I don't screw anything up) in order to save my previous deleted files and download and install new non-deleted files onto my autoCAL.
Josh154
1,220
85
Sioux Falls SD
Brock, my fass came with a little blue piece that clipped into the factory fuel pick up line. I left that in there and ran extra hose off it and plugged it with a bolt and c clamp. I can get a picture in a bit
cdbright
JUST RENT IT
Dec 16, 2008
1,016
Salt Lake City, UT
put 18" blk rims on, not sure i like the look but it sure as hell rides better
picture.php
picture.php
SmokeShow
6,818
Lawrenceburg, KY
Changed the alternator on my truck. It stranded me (battery light been on a few days so I thought the gauge was just bad since it kept starting/running fine & not dipping below the tick halfway btwn 9 & 14V). That procrastination bit me yesterday morning. Not too big a deal though since it was at my house. ;)
Had a 105amp unit on it but I stepped up to the 140amp unit with the replacement. Can't complain about the original unit, it had 195K miles on it unless the original owner had to change it in the first 75k miles. I've put the last 125k miles on it & know this is the first time it's been changed since I've had the truck.
Not a bad job to do but damn it sucked getting the bottom bolt lined up just right. Hell it took an hour to get the bolts back in. :(
1,517
I swapped mine to 140 while back. Helps alot with the truck runs both the grid heater an glowplugs are the same time
MAXX IT OUT
Neglected
Mar 1, 2013
1,791
Des Moines, Iowa
In the process of re redoing my fuel lines and fixing my 3 inch Y bridge as well as building a new intake.
chevor
Highway hauler.
Sep 17, 2015
192
On the Road
I seem to be getting code P0401 daily now. My Edge saids it's EGR insufficient flow. Over 755,000 on the truck and it's never ran stronger.
