minerigger
2,660
Casper, WY
Replaced my airdog 165 motor. Freak when I though I lost the clip to hold the return fuel line off the pump to the tank. Not sure how but it made it safely into the frame rail...thank god. The directions said to remove endcap from old motor and install on new motor. Why when the new one comes with one on it. I didn't so hopefully it's got o rings and whatnot or I'll be needing another one. This new motor is loud as hell compared to the old one. Hopefully I don't go through this again anytime soon.
1,456
Was going to dyno my LMM but didn't get done in time to pull duals and run up to Firepunk Diesel do took my wagon up
First time she has been on a dyno in ~6 years and some 60,000miles. did 305/432 with 200 miles on it and smaller tires
Kinda stoked :)
Video of lavon running her on the dyno
https://youtu.be/XZuIUWsb-jc
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Do you have a draw straw or a sump..?
minerigger
2,660
Casper, WY
Well I'm trying to get one. Also need some optilube. Trying to figure out what they do with the factory pickup on the top of the tank so it's not open?
matt78
Finally boosted launches
Sep 10, 2012
924
texas
Installed my baseplates on my tow bar kit from blue ox. Should be pulling her behind the rig in no time.
UGAfsuFAN
Sep 29, 2015
57
Between VA Beach & Tallahassee
Left Suncoast Converters shop today with my newly built transmission with a Limitless converter! Wow! What a difference! Awesome job! Gotta get a bigger fluid cooler next! Any suggestions?
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
Kinda stoked :)
Haven't seen that around in a while. Sounds like its still running good
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
Hauled three loads of mulch for my parents house, first one was 3yd and def at or above gvwr :D Pretty sure I convinced my Dad to get a baby dmax Colorado after that drive home. :thumb:
13,862
966
I didn't do it today, but I finally welded in the bung and installed the coolant level sensor I got from Dave at HSP a couple of months ago. I hate welding aluminum...
1,456
Delivered couple loads, washed the truck, then built a tail pipe. With a flex pipe coupler. Been busting up hangers when it was all one piece. Got pissed off dumped it in front of the axle.. Now it kicks out at a ~45° just in front of the bumper with a 24" flex joint underneath the tank.
