Got my personal built motor back up and going to do some testing this week. Little background on the build itself, Still running my 15.25:1 Finger's Oval Race CAST pistons on Carillo rods. Billet mains and studs. SoCal AF6480 cam, Socal springs and valves on stock heads un-ported, pushrods, oringed block with ARP 625+ studs, billet bridges and Harland Sharp Aluminum rockers, DHD Cast 3" y-bridge, PPE manifolds and up-pipes, Exergy Performance prototype SINGLE 14mm cp3, Exergy 250% injectors and Fass260 liftpump on street diesel fuel. I was using this to do some turbo testing along with testing this new pump to see what and how it was going to do. Well, turned out we ended up setting a new record for single CP3 with a single turbo record as a result and we are just starting to scratch the surface of what it is capable... With a 91mm turbo I hit 1380hp 1963ftlbs @ 65psi boost. This was with a peak of 305bar cylinder pressure. I think with the right turbo combination and injectors that this pump will be capable of close to 2,000hp! Time will tell but I know my next race project will be running this pump as a single!
https://www.youtube.com/watch?v=iYismzlGXDo
