8,059
From my basic understanding main journals are smaller and needs alot of custom machine work with the older style blocks...
Maybe Mark B /Matt yellow jacket can expound on the difference
All I've read is you run oversized bearings and away you go
1,457
8,059
One of the guys at Danville Performance.. That was not mark b
Hmm interesting
Pulled the limo in for a boost leak check and adjust idle timing. Towing the trailer last week, I noticed a low whoosh noise when boost would just start coming on. Seems the low pressure turbo blew the gasket at the v band connection cause the v band was loose for some reason. Fixed that and added some more timing at idle to clean up some haze
chevor
Highway hauler.
Sep 17, 2015
192
On the Road
Just bought $412 of oil. 2 five gallon pails of Mobil Delvac ESP 5w-40, 2 five gallon pails, and 5 one gallon jugs of Mobil Delvac 1300 15w-40.
Rebates of $195.
$217 after rebate.
Aug 3, 2013
898
Arizona
I took a picture. And drove it
baddaddition
Mar 10, 2013
287
Giving the injector hold downs a once over before bedtime... Just double checking my work..uploadfromtaptalk1446262830641.jpguploadfromtaptalk1446262873596.jpg
Sent from my XT1254 using Tapatalk
