I bet he's referring to the bank account being on a downhill slideHmm...I always thought it was an uphill battle for More Power.
She's dirty, but still looks good. I just bought a longhorn fan shop tune to see how well it does. The Idaho Rob tunes aren't working very well. I've done the tranny relearn and still shifts terribly. I'll be doing the tranny probably by the end of the month.
One of the dumbest things I've read in a while.She's dirty, but still looks good. I just bought a longhorn fan shop tune to see how well it does. The Idaho Rob tunes aren't working very well. I've done the tranny relearn and still shifts terribly. I'll be doing the tranny probably by the end of the month.
To take advantage of the trans you will need a lift pump and new tunes. The down pipe should be done while the trans is out as well. That should put you over the 500 rwhp mark. If you want to race you will need some form of centerlink brace and at least tie rod sleeves. My advice is don't go cheap on anything and always do what you think is overkill. I have found every time i say this will be good enough for my goals i end up changing my goals and wishing i had gone bigger initially.
after the transmission upgrade can I go to a higher level?
What lift pump do you commend?
What lift pump do you commend? And also down pipe?
Update:
Last week stopped by Inglewood Transmission. Mike did one hellova job. Shifts great and feels awesome. Ordered a FASS 150 which will be installed next week. Then new Idaho rob tunes. Can't wait. And also beefed up the tie rods and whole front end.
