Upper control arms
bonac05lly
Jan 7, 2014
20
NY
What are your opinions on the best upper controls arms to get? It's for an 05 2500hd 4x4. Thanks in advance.
moparkxracer
2,309
33
Out and about
Djm makes them for lowered trucks. I am using Cognitio's. They are flipped upside down and swapped sides to get ball joint angles strait.
JDub
607
Hooper, Utah
Been super impressed with my Kryptonite UCA's. Installed nice and are beefy as hell
RPM Motorsports
smokinum
May 13, 2008
3,271
10
Central Valley Ca.
Do some research on the product your buying if your looking for an arm that will benefit what your doing. DJM and Cognito have the ball joint angle adjusted for leveling or dropping, the other mentioned is a fancy stock replacement part.
SoCalMike
851
79
California
If your dropping the front stay away from cognito uca's. It puts the ball joint at a bad angle when lowering it lower than stock. Also you will not be able to get caster in spec. Stick with stock. And if you go with stock uca's replacements don't get ac delco. There ball joint design stops the uca's before the uca's hit the frame stop. I have to replace my 2 month old uca's because the boot is coming apart because of there crappy design. I went with moog uca's this time....
8,236
there is a certain way to run the cognito UCA if you run the truck lowered....
SoCalMike
851
79
California
If you talking about running the ball joint from the top of the uca's I did that. I had flat cv's and the ball joint angle was bad. I cranked it up 2 turns and it made it a little better but they still could not get caster in spec. I did not try flipping the uca's upside down though....
wrcknkrw
447
roy ut
I tried cognito UCA when I took my lift off and sat lower than stock. I was unable to get in spec at all either.
8,236
Is there an advantage to running cognito uca's flipped and on opposite sides vs just stock arms on a lower than stock height truck?
besides someone bombing it off road, not really for 90% of the people out there. you have a better ball joint attachment with a cognito arm and the joint is a bit bigger but thats about it. if you were going for max suspension travel, i would recommend them. what im stating is more for those that have a leveled truck and want to go lowered.
SoCalMike
851
79
California
I would have saved some money doing it this way. Actually I would have not spent anything on stock replacements. Just time and money for alignment.....
S Phinney
4,008
Quncy, Fl
I gave zero problems with Cognito UCAs and the truck being lower. All alignment specs work fine and no wear issues. Truck drives good and handles good.
andy-stevenson
Jul 7, 2013
838
I thought they were similar to cognito and gave better upper ball joint angles for lifted/leveled trucks?
