LML mods and dyno testing begins
Mike L.
Got Sheep?
15,686
232
Fullerton CA
Let's keep this thread going as I am learning and enjoying this. I may have to duplicate Rob's mods. this is good stuff here.:D
fast03
1,201
60
Rancho Cucamonga
Exactly Mike! You and I talked about having a great running truck and not removing emissions stuff. Hope this is where it goes. Also wanting to be able to tow with whatever set up comes out of this. Gotta say its a beast stock when the trailer is behind it.
IdahoRob
Jun 5, 2007
1,151
OK, don't shoot the messenger. This test was done with same stock tune and same performance tune as the first test, within hours of the first test, same dyno, same load and correction factor.
We didn't believe the results so we made multiple runs and all were within 5hp.
My stock intake had 17k miles on it and we didn't clean the MAF or anything else but installed the new intake with a dry filter and a filter sock.
I'm going to review the MAF readings to see if the improved air flow allowed the ecm to add fuel. Either way 40hp on stock tune and 20hp on performance tune is really unbelievable. If someone else did the test and I read it on the internet, I'd say B.S. so take it for what it is. Even if it was half that on a stock truck, very cheap HP.
  • lml intake test.pdf
IdahoRob
Jun 5, 2007
1,151
I don't see the ecm adapting, once I get some time i'll look at the logs and see if I can see the reason behind the HP increase. No codes on either tune with the intake. I'm running 34.5" tires.
IdahoRob
Jun 5, 2007
1,151
On the performance tune with the intake it boil the tires up through 3rd gear, even will smoke them pretty good from a 20-30mph roll.
$chultz38
230
Is there any modifications that could be done to the factory setup to make it flow better like the older trucks did?
Awenta
4,090
That's crazy. I would have never believed it otherwise
9,901
148
I might have missed it but if not can you put up a list of parts and whose they are that you are going to use Rob?
Mike L.
Got Sheep?
15,686
232
Fullerton CA
So with new intake and dry filter, will the computer eventually "tune it out"? Did you get any maf or other codes?
If you get a MAF code, it will not regen and the ECM will assume that the Particulate filter is plugged after trying 5 times . It will then go into a limp mode and give you a 30 mph top speed. Real fun trying to go up a hill.
Ask me how I know.:(:D
sickdiesel
Apr 22, 2010
1,019
So far the only mods on the truck are S&B dry filter intake and Mike L's trans with Robs tuning.
Plan to put on a Fass 150, Fleeces CP3 conversion, and Marks new 4094 Stage 2R in the next few weeks.
all emissions equipped :)
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,162
10
idaho
I tell people lmls really see a difference with a s&b everyone said I was full of shit to
