LMM: New Danville 68MM Stg2R Review
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,152
Wilmington NC
www.mydieseladdiction.com
Eeny, Meeny, Miney, Mo.
Can't wait to see what one of these Stg2R's is like in comparison to the other 3. By the way Shields, you need to call and get on the schedule for the trans, and while it's out.....
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
look at all those ! I'm assuming far left is the 3794 third over is the stg2r not sure about the other 2?
Btw Dustin do you remember an 07 lbz crew with 100s and a stroker pump? Dark grey, guy named Jonathan owned it? A good friend of mine owns it now he's in his 60s lol
othrgrl
Mar 10, 2008
2,152
Wilmington NC
Left is BMW3794, then the same turbo that is on the truck you mentioned, then the 68mm Stg2R, then the 72mm billet.
It's unfortunate for Jonathan that he had to let the truck go to buy or build a house, he still misses it. We did the turbo, 100 overs, 10mm stroker, tuning, and a few other things on the truck. The truck was really starting to dominate stock class then he sold it.
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
That truck is wicked man ! Its a shame it will never get put to full use anymore it's the fastest truck I've been in to date I'm trying to catch him !!
N2BRK
2,393
733
I run mine even lower, but I re-wrote my TCM to tune to keep it in 2nd and locked up until 8mph on decel in T/H mode. I get a lot more help coming to a stop sign than I thought that I would. If I wind up doing a slow roll and not a full stop, I can always pull 1st gear on the tap shifter to avoid a situation where I'm bogging down the truck trying to take off again.:thumb:
1,517
1400 gets me below the downshift point when coming to a stop.. TCC engaged/disengaged at 11mph.. Problem I have is OEM TC is so loose (IMO) TCC won't engage on part throttle acc till 30mph basically 3rd when the truck is loaded, when starting out going up a grade.. I have always been under the impression the TCM won't engage TCC when there is more than 750rpm difference between engine rpm and input rpm on the transmission. Though I have not found any supporting data to back that up..
yellowchevy
1,933
93
Louisburg, KS for now
I installed a 3794v today on an LMM for guy and it drove great. Very responsive and pulled hard through all the gears. It dropped a little when it shifted into 6th but very minimal. When comparing the stock LMM to the 3794, the 3794 was more responsive and drove great.
Not to mention it sounds good!!:D:woott:
Great job Mark, very nice work!!:thumb::thumb:
Yellowchevy
