Is there a problem with getting the temp from the oil pan?
No there isn't.. Just need a NPT boss put on it.. Sheet metal is pretty thin to run it without a bung
Brian is referring to the last picture in post #4, There the sensor is in after the cooler, not the ideal place to monitor oil temp.
I'm using an aftermarket pan that has the fittings. Didn't know if it was a poor spot to get the temp from.
Correct, that's what I meant. sorry
Do you have the :dancenana: pan?
Yes I do.
So theoretically which is better. Oil pan or that fitting? Or basically the same thing.
Replace oil drain plug with a sensor? Haha
With the temp sensor in a port that is after the cooler the oil temp is the same as the coolant temp.
That's not 100% accurate.
In theory that's how it was designed but does it do that...no
