Has anyone put an other then LML built short block in a LML duramax like an LLY block in a LML? use a built short block from a LLY and bolt the LML top end on it is what Im thinking.
How come front balancers and flex plates are different for lb7/lly and lbz/Lmm? Thought cranks were different????
Water pump and timing cover differ as well. But yes you can ^^^
If your gonna do this buy those 40% from silver king on here. Should be equal to 100% LBZ sticks...
Are you saying that LML 40% injectors flow the same as 100% LBZ injectors?
