Why not up the power if your struggling to perform on the grades?
he isn't using an allison
If you're not keeping up on the highway Adam, your not making as much power as before, and turning it up gradually to the point where it is pulling the same as it was before is not going to hurt the tranny.
However, I strongly suspect something else is going on. Boost leak, pre-turbo exhaust leak, clogged intake filter. Something.
That was my thoughts, it is obviously down on power if you can't do the same as before, it seems as though these pistons take a different mind set as far as tuning is concerned
Also I got better MPG in my old 95 3500 than I do in this 08 2500. It may have had a lot less power but it had better MPG. It ran empty at an avg of 24 MPG best I ever got was 27 MPG on a 32 hour drive out west when I moved out there and the box was full of tools and all my stuff.
so to update this... from 4-30-13started pushing coolant slightly on a light high wind drag load...ect no higher then 210*...ordered new LML grade As along with the new LML (silver/galavanized look not black) bolts.. on tear down found 3 injectors that where carbon up and indications of not sealed..... one of them was frozen in the boss..no visible indication of where the coolant was getting through....
found out that the rocker shaft bolts shoundnt be used more then twice... OEM is 10.00 each arp for the bolts is 5.00ea easy choice there, replaced the injector clamp bolts with 8-1.25x60mm 8.9 bolts with washers, waiting on new injector hold down to come in.. the hold down seamed bent a little on the frozen injector..
really glad i didnt turn the wick up...
heres the only pic i took.. tried to wipe as much carbon out as possible still running 1000uS @ 20-22* WOT
also the plan was to throw in gapless rings to help seal up the champers and increase effciency.... probably worth .5-1mpg with the rings..... aint much for the avg guy the DDs but when you math it out @4.00 a gallon times 100k miles a year, its good for my wallet and the enviromenti could also see the gapless rings help alot in cold weather
Great results and you must be quite happy about how it all turned out.
Will those gapless rings fit the stock pistons or do you need to have them machined for it?
Any links on the rings?
