Broviak built his so I guess I'll build mine too
smkndmax05
"Smoked Out"
Feb 17, 2011
479
Indiana
I guess I'm taking the plung into the built motor world. I'm expecting the block back from the machine shop Wednesday, then assembly will start. Build consists of Carrillos, PPE 15.5/1 cast race pistons, 3388 SoCal cam, SoCal Stage 1 heads, MA pushrods, Socal dampner, billet flexplate, head & main studs, 100 % Exergy injectors, dual fuelers with modded LBZ pumps. I'll be running our DP 72mm as a single for awhile then possibly twin it later.....
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
Sounds like a solid build!!.....Do you care to share the reason why you'll be using PPE pistons over the Fingers oval bowl pistons?
jmaz268
Lead from the Front
May 20, 2010
2,895
40
Springfield IL
Figured you would go Fingers pistons as well.
Sounds like it should be a runner for sure though. Don't see too many guys with SFA going big.:thumb:
smkndmax05
"Smoked Out"
Feb 17, 2011
479
Indiana
It was a tough decision. I guess my budget and we will get to see how the round pistons react vs the fingers on compression ratio.
