Looks good, I have to ask, is the stock Y bridge welded together?
If you tig the stock one, how do you get to the bottom 2 bolts to put them back in??
Looks good Russ :thumb: I don't think I would have posted up that before pic...that is one dirty engine! :rofl:
We built 2 braces to attach to the flange at the Y bridge but they apparently didn't hold. The Y bridge blew out yesterday at the bottom and ripped an o-ring.
For a quick fix, I bought a "oil adapter and cooler gasket assortment" from the HELP! section at orielly's. part #82560. Has the perfect size o-ring for the stock Y bridge.
Then I took 2 large hose clamps and strapped them around the Y bridge to hold it in place, made an "X" along the back to pull them against each other. With this and my braces up top it isn't going anywhere but it sure doesn't look pretty if you look down in there!
I'll end up tigging the stock Y bridge or buying a new one from one of the fab guys.
^^^ I assumed that, but didn't know if there was a trick to it or not. I just strapped mine.
They are much laggier than I expected. I'm sure Josh will be able to get rid of some of my lag. Going to get him so logs today if it doesn't rain.
No dought o korys abilitys but im sure josh will hook him up pretty good.He did a hell of a job tuning Russes truck before the twins.Btw Russ I would have liked to see you take a run at the quick 50 list before the twins but oh well who doesn't like twins :roflmao:I don't know Josh or his abilities as far as a tuner but if you do not get the lag out I feel very confident that Kory Willis will. I worked with him and he is probably one of if not the best on the LBZ / LMM tuning. Good luck:thumb:
If josh hasnt messed with rescaling the MAF yet, that can be alot of the lag you feel
