The top pic is the pig-tail connector for the cp3.
nope, its for the MAP sensor pigtail.
Bottom pic... alternator?
Top pic looks like the oil pressure / level plug.
truck has to see X rail pressure ( 700is-800is i think ) before it will fire the injectors .
Well i know it's not the Cp3 plug cause i only took that off once and it went right back on.
Ben is correct that the alt wires are browish, and both alts are plugged in.
This is the MAP plug, it is on the pass side, on top of the valve cover.
That isn't the plug Ben is talking about. He is saying there is a pigtail for the MAP sensor like the one for the FPR. From what I can tell in the pics, the colors on that connector match the colors on the MAP sensor.
From what I can tell of the wires in the other plug, it looks like the vane postion sensor plug. If you can post the wire colors on both plugs, I'll try to tell you for sure.
irregardless, neither of those connectors being unplugged should stop it from starting.
The only sensors it needs to actually start is fuel rail pressure sensor, cam position, and crank position.
