LLY: EFILive DVT's...broken...?
Leadfoot
Needs Bigger Tires!
Dec 27, 2006
905
31
Western MA
www.matpa.org
I tried to do the test today both with a mechanic's stethoscope and with an electrical test pen (like the ones used for detecting voltage on wiring, likely only works on AC voltage though) and after shutting each one off successively I wasn't able to tell if the injector was on/off. Now I didn't have a helper so doing it by sound was hard to say the least. So I'm at a loss for how to verify beyond unplugging an injector (not sure if it is even safe to run like this) and then try shutting them off successively until I find one that doesn't change the idle at all. I could hear the idle change when I did it so I know it wasn't an error on my part (ie an injector definitely turned off). I also don't have a clamp on style ammeter or I would have tried that too.
Does Cindy or anyone else happen to have any other ideas for how to test them?
I'm happy to do this, but I'm stuck at this point. It would really be nice to get this mystery solved conclusively though.
If you log balance rates, and unplug a single injector, I'm ASSuming it would show instantly. Or check rates, shut off vehicle, unplug injector, restart vehicle, check balance rates, repeat.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
The problem with unplugging one injector connector is that the ECM will immediately sense the open circuit and put the engine in limp-mode. The limp-mode that is associated with an open injector circuit shuts down the affected injector control bus, so you're left with an engine that is only running on 4 cylinders. The injectors are fed constant power, and the ECM (LBZ/LMM) or FICM (LB7/LLY) switches the ground wire going to the injectors to actuate them. There are two injector + power supply busses, A and B, with each bus supplying constant power to 4 injectors. So if there is a short/open-circuit somewhere in the injector wiring, its physically impossible for the ECM to isolate and disable that ONE injector, so it has to shut down the whole bus.
So its basically impossible to narrow it down that way (by unplugging one injector)...
Leadfoot
Needs Bigger Tires!
Dec 27, 2006
905
31
Western MA
www.matpa.org
Now that you write that i remember you (or someone else) stating that previously :eek:. That being said, what would you see as the easiest way to map it. My beater should be up and running in the next day or two, so I can "play" with my DMAX if needed to help with this.
PS. What does that DIC read in your avatar (too small to read it...)
mtl_dmax
114
Eastern Canada
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
That's a good idea, anyone know if the kit from Harbor Freight has one that will fit with a duramax injector connector?
http://www.harborfreight.com/11-piece-noid-light-and-iac-tester-set-97959.html
The 48V could be an issue too since most gas motors use alot less voltage to fire the injector.
But again...even with that kit...I think you have to unplug the connector and plug it into the noid light. You cant unplug a duramax injector without the ECM knowing and going into limp mode
mtl_dmax
114
Eastern Canada
Shoot, didn't know that.
So it sounds like the best way would probably be some sort of clamp on ammeter provided it fires long enough to register on the meter.
I'm actually surprised Fingers hasn't piped up about this issue at all yet. I'm sure he has been down this road already, or at least could offer some insight. He's a pretty fart smucker when it comes to this stuff!!:D
rcr1978
793
Spring Creek, NV
I have a oscilloscope just no time to deal with it at the moment, your still going to have to feed paperclips through the back of the connectors so they are not unplugged so you have something to hook the test leads to, might still be able to smoke autozones noid lights for them that way :angel:
mtl_dmax
114
Eastern Canada
I don't think you need an ocilloscope if you're keeping continuity between the connectors/injectors. The event is quick, but even a few milliseconds should be enough to see a flash on a test light. I should be able to rig up a custom noid light, but now I'll need to find a light capable of 48V DC though. Just thinking out loud, I could probably string a bunch of LEDs together to get 48V pretty easily and they would barely take any power to light......I could also use a large resistor w/single LED, but that may affect the injector firing......I may need to experiment with what works. It would also be nice if I could also find part of an old injector harness connector as well (like when you do the #2, #7 fix) to make the tester with.
rcr1978
793
Spring Creek, NV
I wonder if the numbering is the same between the Delphi and Bosch ecms? If I can get at mine easily without pulling shit off I could test a LMM and a LB7 with a scope. I will see if I can find a decent pinout for the engine connectors so I don't have to go digging to get at all the injector harnesses.
What about the injector pulse width?
What's the typical timing for that (in ms) at idle?
I thought it was around 3-4 ms.
PW should work. If you cut an injector, the PW for that injector should go to 0.
If you have access to a TECH II and are willing to test, send me a PM detailing what vehicle you have to test on and I'll send you the test list.
Our next public release is scheduled for this week, so we won't be in a position to analyse data until after the release is bedded down.
Cheers
Cindy
Um ya it would Ben.
My Labonte W/M measured PW by tapping into the inj. harness power for one injector and used that PW to control W/M injection. If you were to shut off that injector with EFI, it would read zero PW on the Labonte display.
This essentially is what we are looking to check no? Which hole shuts down when selected? Determining if it's firing order or physical location that is shuting down right?
mtl_dmax
114
Eastern Canada
I'm thinking that if these events are below 1ms (looks like on EFI typical pulse width is around 0.3-0.4ms) it may be hard to see a noid light flashing that fast although it may still be possible (you can see down to 5ms okay, but not sure as time values drop to 1/3ms flashes at idle). Using an oscilloscope would certainly be easier because you can set it for different sampling rates and it would seem pretty easy to modify an old injector connector pigtail and to add pins which allow a straight through connection while still being able to clamp onto the pigtail and monitor the injection event. I know there are also automotive DMM's that have the ability to test transient voltage pulses down in the 1ms range so that might work as well......unfortunately, I just don't have one of those yet. If you have the time to try it with the scope that would be awesome and I will try to verify the results on mine as well.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
Um ya it would Ben.
Ok sorry my mistake, I misinterpreted your post. When you said "cut an injector", I read that as/thought you meant "cut an injector wire", which would put the ECM in limp mode and shut down that entire bus..
