Billet Flexplate 650rwhp?
Mikey
Drag Racer
Jun 13, 2009
560
If 650rwhp is made with an LBZ, will the stock flex plate hold up or should I upgrade?
ripmf666
15,123
14
49
Wentzville Mo
Its hit and miss on that. Some have been fine running a stock flywheel and some have not with alot more power. I'm still running a stock flywheel in my truck.
F
FrankenMax
Guest
If you got the cash and your already planning on digging in to the trans it wont hurt.
8,051
Ill be running that hp if not more and a stock flex plate. Mine still looks like brand new at 500-550hp and 36k
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
46
slc tuah
I ran a stock flex plate all last year in the low 10's high 9's , it was still perfect when i pulled it out , I have ran across many cracked and a few broken , HP didnt seem to be the common denominator though , so i guess its any ones guess , I wouldnt run the billet unless you have to , I personally like that the stock piece has some flex to it , it could save some shock load on other parts.
Mikey
Drag Racer
Jun 13, 2009
560
Thanks all for all the reply's. The information we share is priceless!
Thank You too Mike L.
I have a factory GM Sevice Manual and will follow it to the tee. I had to remove my flywheel so I could get into my oil pan off and am now reinstalling
