Top 25 Stock Duramax's
Dudgy
Runaway
Jun 1, 2010
416
Alberta
Running a tune from a buddy. Waiting for Simon to come back home and sit down with him one day and get it fine tuned. It's still a little rough on the shifts and some runs it falls flat on it's face in 3rd gear.
It got quite a bit faster as it cooled down at 9-10 PM. Ran a couple 12.36 runs and two 12.25 runs. Then the very last one at 10PM was the 12.18
I also started launching harder than last weekend. My last run I actually spun all tires off the line. It frekin ripped. Felt very strong off the line.
Egt's hit 1700 around 1/8 mile til the trap. Cookin er pretty good, poor turbo, hopefully it stays together this weekend lol. I'm launching softer tomorrow cuz it's bracket racing, just wanna be consistent
Dudgy
Runaway
Jun 1, 2010
416
Alberta
Congrats!! What all is done to your truck? Any video?
Billet PPE race tranny built by Santech Diesel Performance
Lowered
Cognito tractionbars
Proflow manifolds, uppipes, air horn
Banks wastegate
Banks intake with superscoop
Diamond eye downpipe
4" exhaust into 5" stack
Big tune
325/45 M&H drag radials on 17" XD Revolvers
Lotsa weightloss
Fass lift pump
3,422
get a video up
dyno numbers are way low for those et's
Using the forum calculator, for the weight and mph the hp is accurate. Surprising none the less, but thats the whole point about weight reduction...you dont need as much hp as a heavier truck to go as fast.
The ET Im not so sure of. The 1/8 split is 11.9x range. I'd bet the sea level track/good track prep had something to do with that.
Dudgy
Runaway
Jun 1, 2010
416
Alberta
Sea level makes a big difference. And the track is really nice. They didn't spray any vht but we don't really need that in 4x4. Although I had a little tirespin off the line on my 12.18 run. Launched hard
Dudgy
Runaway
Jun 1, 2010
416
Alberta
I'll upload the video later this week cuz Internet is too slow to upload here in the hotel.
Here's the timeslip and dyno sheet. I'm #5567
Kat
Wicked Witch of the West
Aug 2, 2006
17,900
20
62
Norco, CA
Just hit 512.8 HP on the dyno
Truck is 6100 lbs.
I think you have more HP:D... Just looked at your dyno sheet. Mustangs read low. They don't work well on diesels from what I have seen.
Edit. There is something wrong I don't think I have seen that much tq.
dordtrecht5
Regular Cabs Rock
Jul 21, 2009
900
Wherever I am working
it also depnds on the calculator that is used. The one that I use that is on nationaldrivetrain.com it shows at that weight and HP level to be about a 12.68 run. Something is amiss with the whole thing because of the dyno sheet as well. I think that KAT is right about the torque figure, that would have to be the world's record for a stock engine Duramax. Still don't know if it is a stock turbo yet.
Even yet a different calculator shows at that weight and mph, the truck would be putting out almost an even 600hp.
I remember that trent's 9.3x run was called off because of a bad time piece. If it's real, congrats Dudgy.
Dudgy
Runaway
Jun 1, 2010
416
Alberta
I haven't touched the turbo, injectors, cp3, intercooler, anything like that.
Here's some pics of the engine bay. I wouldn't post in here if i had any of these parts changed for aftermarket. I was really surprised that it ran that fast as well, wasn't expecting to get that close to the record.
Dudgy
Runaway
Jun 1, 2010
416
Alberta
Torque isn't accurate, they didn't calculate torque, only horsepower. Everybody ran 2000-3000 torque haha
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
central Ohio
Congrat's!!
You have figured out the hardest part!!! The first part of the track. That time slip looks just like mine. I don't remember the exact numbers but I also run high 7.60's in the 1/8 at 88 mph. It's hard to make the trucks run the bad half to get the numbers in the 1/4. I run my numbers on a totally stock motor,manifolds,intake everything so i'm sure with your mods you run run faster. Congrat's again and good luck. Jeff
3,422
Dudgy, thanks for the pics.
Time to update for you. What is your first name?
1) Stingpuller (Jeff) 12.15@108 LBZ
2) Dudgy (Rony) [email protected] LB7
3) N20Dmax (Buck) 12.18@xxx LB7
4) LBZRcks (Jason) [email protected] LBZ
5) JD4440 (Chris) 12.26 @107.4 LBZ
6) RickDLance (Rick and TJ) [email protected] LLY
7) TheBac (Tom) [email protected] LB7
8) Moss022 (Jeremy) 12.34@108 LB7
9) twistedlogic010 (DJ) [email protected] LMM
10) 05chevy (Bobby) [email protected] LLY
11) skintback (Sonny) [email protected] LLY
12) DrHolliday (Chris) [email protected] LBZ
13) Dmaxchris (Chris) [email protected] LBZ
14) Redbowtiesx2 (Beech) [email protected] LLY
15)Tomac (Mike) 12.49@107 LB7
16) Kat (Kathy) [email protected] LBZ
17) llybully (Kenny) [email protected] LLY
18) GMC-2002-Dmax (Tony) [email protected] LBZ
19) duramaxgirlLB7 (Kelsie) [email protected] LB7
20) rnolan (Ryan) [email protected] LB7
21) Carbon04 (Daryl) [email protected] LB7
22) Noreaster (AJ) 12.55 @ 107.9 LB7
23) UPnGONE (Scott) [email protected] LBZ
24) gmduramax (Anthony) 12.56@106 LMM
25) dirtymax1 (Justin) [email protected] LBZ
Bumped:
JST (Jeff) [email protected] LB7
