LLY: my truck's weird issues...revisited...again
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
ok I might actually take my truck to the track on april 17th for that diesel day at lebanon valley. This will be the first time ive been to the track in almost 4 years, I want to get some times with my twins so I can say they are "proven" and maybe start selling some kits.
ive been working constantly on tuning and I am making some progress finally.
Ive narrowed it down to either a MAF or TCM issue. Im leaning more towards MAF.
Im basically starting over from scratch. I flashed a completely stock tune into my ECM. When I say completely stock, I mean completely stock. All DTC's enabled, etc. I full flashed it with a Tech 2 using the latest ECM update from GM, to rule out the problem being with efilive or the way its flashing my ECM. (flashed it the exact same way the dealer would)
As some of you may know there are two different calibrations from GM. One for the stock airbox, and one for stock trucks that have the LBZ-style airbox retrofitted. At one point GM's overheating "fix" was to install an LBZ airbox, and this of course needed a new MAF calibration to work properly.
So I started with a "cylindrical airbox" stock LLY calibration. Within 1 minute of just idling after reflashing it, it threw a P0101 MAF code. Hmmm interesting... So I cleared it and went out and drove it. Seemed fine, but after driving it for a little while and doing a couple WOT runs, the 4-5 shift started to get funky, like it started getting this big defuel (like the LBZ 1-2 shift defuel). Then I would try again and it would be fine.
Then I went to get on the highway and right after the 4-5 shift (with the big defuel), it did those surge/huge defuel things that it used to do.
SO. TO EVERYONE THINKING I SUCK AT EFILIVE, IT WASNT MY TUNE!!!! Because it clearly does the random surge/defuel events with a 100% stock tune. :p:
And it is random, sometimes I would floor it on the highway and it would do a 5-4 kickdown and accelerate normally, then Id do it 2 minutes later, it could kick down, rev up, and right around 3100rpm it would start defueling. ITS NOT A MECHANCIAL problem or fuel delivery problem because I can clearly see the requested torque value jumping all over the place, from the normal (stock) ~550-590ft lbs WOT values down to 330, 280, etc... And of course the mm3 (main rate) follows that torque value which results in the surging/loss of power.
I still need to flash the TCM back to "real stock" with the tech 2 to try that and see if there is any change.
If there is no change then I will flash the ECM to "real stock" (tech 2) with that normal airbox (non-LBZ retrofit) stock calibration and see what that does.
Im not sure what others have found, but IMO the LLY really seems to depend a lot more on the MAF than we think...I might look for a new one/good used one and throw it on there to see what happens..
ben
993
Ben, have you logged MAF to see if it is jumping around when the defuel occurs? The P0101 code could just be from the twins. With twins, my truck always throws them if I don't have the code parameters modified.
993
What kind of boost are you seeing when it happens? Could it be related to MAP?
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
ben i have a couple maf tricks up my sleeve from back when i had my twins on give me a call if you are still having troubles :)
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
the MAF code trips after you start/idle it for only a few seconds.
The LLY doesnt read any higher than 37psi, its more RPM related than anything... ~3100rpm
Cougar281
1,981
409
St Louis, MO
If you don't have the LBZ airbox, then running that cal will do wierd things as the MAF flow rate will be off. The tube between the airbox and turbo is bigger on the LBZ so it flows air differently. That's why the ECM needs to be recalibrated when the LBZ airbox is installed.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
No I realize that, but I figured Id try it out and see how it reacted with the twins because obviously the twins have a completely different "air box"
custom8726
2,784
Upstate N.Y
Hopefully you make it over to the valley, It would be good to meet you, and I would like to check out the twins:) I will be there for sure and hopefully racing if all goes as planned..
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
ok now I just tried doing some testing with a *completely* stock LLY tune (designed for trucks with the stock LLY square airbox.
No surges... interesting. So it seems the MAF is critical, at least on LLY's.
Even when all of the MAF-related DTC's are disabled, and even if you set all the diagnostic test-enablers out of range (ie, dont run MAF diagnostics if coolant temp is below 300*) it still doesnt like seeing discrepancies between the MAF sensor readings and expected airflow tables.
Also......another oddity I noticed. With these stock tunes, if I do wot acceleration from like 40mph to 60mph in tow/haul, when I let off the go pedal and it goes to 0%, the TCC unlocks. Even when its in tow/haul mode. :confused:
strange.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
also...does anyone have any idea how the LLY references torque...ie, on the scan tool its always giving out a torque reading, ie, "what torque level the engine is currently at based on load, throttle position, fuel rate, etc"
I guess thats really only a question for the EFILive crew though.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
another thing; on some of the 4-5 shift defuels, SOMETIMES it would defuel to as much as 74ft lbs, or like 30 mm3. Other times it would do a "normal" defuel, to like 80 mm3 or something.
Remember this a 100% stock tune, as flashed by a TECH 2.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
46
slc tuah
Ben , I had to fix a LLY defuel issue yesterday , the base torque tables for MAF were screwing us over , I made all 3 base torque tables the same to match the "race" torque table i use and between those changes and a few others i couldnt believe the difference it made in the truck , the driver left grinning ear to ear , and this is a built motor LLY with twins ,dual C's and the works probably a 800 hp truck , just something to think about may not relate to your truck but i know for a fact that the truck didnt have any defuel problems when it left :thumb:
GMC_2002_Dmax
The Still Master
I get asked quite a bit by my customers if I rescale the MAF sensor for twins, for airbox mods, for any reason and the answer is NO.
MAF is used to limit fueling based on the B0751 and B0752 tables in the LLY ecm file. This is also changed from the factory for a cylindrical or square air box because the stock MAF, stock BOOST and other parameters are monitored closely in a stock tune for many reasons and will throw you into limp if it goes out of range.
Ben, you have no airbox, you have two turbos, the location of your MAF sensor is in a very different place than it would normally be.
There is a way around it, if you have time stop by and I'll help you resolve the issue.
:thumb:
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
IMO I think the torque limited injection quantity and base torque tables (for the LLY) are slightly misunderstood/mislabled in EFILive.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
no Tony, I have both tunes right in front of me (stock LLY for the square airbox and stock LLY for the LBZ airbox) and B0751 and B0752 are identical between the two.
The only difference in the two tunes is B0201.
ben
TrentNell
Jul 7, 2008
7,543
46
slc tuah
Trent what do you mean "base torque tables for MAF"???
do you mean B1103, B1104, and B1105?
I max B1106 , and yes i made B1103, B1104 , and B1105 the same based off of the table i made . But B0742, B0743 , and B0744 all have to be setup right also . . The MAF seems to play a factor in the torque tables in the LLY , to be noted I didnt change his current MAF tables nor did i check what they were setup at.
The description below is fairly vague on how the base torque is used , from my experience, the base torque, and TLIQ table is the grand daddy of all the fueling tables and is used far more than just when a shift occurs ,and will over ride most other limiter tables .
"If the ECM is trying to limit engine torque then this table will define the commanded injection quantity value based on the torque value the ECM is trying to limit to, but only if MAF flow is within the range of {B0902} "Injection Timing (MAF Map A)" or barometric pressure is within the range of {B0905} "Injection Timing (Baro Map A)".
This table is responsible for the 'de-fuel' effect during transmission shifts as the ECM attempts to limit engine torque as requested by the TCM"
