6 speed trans tune
13,598
632
This tune has been matched to the race tune I posted. It is pretty basic with mods to the torque tables and 4-5 and 5-6 shifts. It is also setup to lock the converter early in regular mode (non T/H).
  • TCC Tq Control early lock_0001.tun
E.carter
637
Princeton, Iowa
Thanks for the response Rob. I know nothing on tunning and am always a little scared to try new things as I have put alot of time and money into building this thing. I sure am glad there are guys out there that share there knowledge on this stuff.... If you ever need your John Deere combine tuned let me know.... Thanks
Eric, if Josh posted it, it'll be fine to test. He knows what he is doing!
13,598
632
I ran it in my truck for a while with no problems. I got tired of the early converter lock though, so I changed that back to normal.
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
Post #5. I ran it for about 3 weeks and liked it but took it off because my wife had to make a comment every time the converter locked soon. It was smooth as can be at the strip though!
DetailsUnlimited
1,264
Benton, Ar
Do you have to run this with/ or with out the TH? How long should you run this tune so the tranny learns it? I have alot tied up in mine too! Not as much as some but, from what I can afford.
thank you for your time!!
SmokeShow
6,818
Lawrenceburg, KY
I was right, check the classifieds.
Oh wait, you're in KY so you might have got the PM too??? :angel: I don't really give a chit, it's just funny.
tunderwo3
Nov 17, 2011
is there a easy way to switch operating systems in the program when they dont match vehicle to tune
4,812
393
You need to make a script. There are several post on it for tuning and the trans is done the same way. You need a stock tune with the same OS as the modded file, make a script of the 2 then write that script over your stock file with your OS.
