Do you think I should keep the ranchos set on 9 still?
yep
TheBac, did you order your QA1s from summit?
Yes! One day service! Gotta love Summit.
I have them in the garage right now...just have to go buy two 1/2"x2-1/2" bolts so I can install them tomorrow night.
These dang things are rock-solid stiff on the top setting! Set it on 12 and tried to compress the shock.....wouldnt move, even with my whole weight on it.
Try pulling up on them. You want a stiff rebound, not necessarily a stiff compression.These dang things are rock-solid stiff on the top setting! Set it on 12 and tried to compress the shock.....wouldnt move, even with my whole weight on it.
I dont think that'll be necessary, would it? Grade 8 bolts should work fine, shouldnt they? I tried to find a 12mm(?) sleeve yesterday, with no luck. Maybe my fab shop will have something.Did you end up welding your shock mounts and redrilling them is that why you need the 1/2'' x 2 1/2'' bolts?
Tried that too. No go.Try pulling up on them. You want a stiff rebound, not necessarily a stiff compression.
yes grade 8 is good
you need to either do it one way or the otherTrents way or my way both are just as good but you need to do one of them
you have a 12 mm sleeve in the old shocks dont you?
they dont have to be the thin ones , you just thin out the bushing with a drill bit . or do simons method , page 1 has some really good picsI'll have to go back and see what your way was....I dont remember it.
Found out today the bolts are 14mm. Nobody makes thin sleeves in that size. I couldnt even find 9/16" sleeves...they go from 1/2 to 5/8! I'm just going to install them like this for a few days, then fix it when I get time (and can think of a decent solution) this weekend.
--Because --
No way am I destroying my old Bilsteins just to get a couple sleeves. I threw my old stock shocks away years ago so I dont have them to fall back on. .....and my wife wonders why Im a friggin packrat about autoparts....:rofl:
--Because --
No way am I destroying my old Bilsteins just to get a couple sleeves. I threw my old stock shocks away years ago so I dont have them to fall back on. .....and my wife wonders why Im a friggin packrat about autoparts....see what happens the one time I do need a weird part?:rofl:
they dont have to be the thin ones , you just thin out the bushing with a drill bit . or do simons method , page 1 has some really good pics:rofl:
For the bottom I used a 1/2" x? bolt grade 8 was considering a grade 5 untill I seen what GM uses.Simon, do you have any pics of your set up? and what size bolts you used?
thanks
Rob
