Twins with Twins, Anyone?
kidturbo
Piston Tester
Jul 21, 2010
2,804
1,804
Somewhere On The Ohio
www.marinemods.us
Well that’s disappointing, but at least lml salvage values are falling so plenty of trucks available for parts.
What issues did you find with the L5P block?
Few pages back it was brought up.
Lifter have issues. Oiling related or just cheap part, needle bearins seem to fall out. Never an issue before.
Biggest issues is rods starving at startup due to some geniuses CAD blunder. Unless ya know of someone else, think I'm still the only guy to ever spin rods bearings clean out of a duramax. And then weld up and reuse that same crank. Is my first post here on the PPE boat I believe. Wasn't a GM issue, was marinization mistake by that crew that starved it for oil.
Sent from my SM-S906U1 using Tapatalk
How hard is it to modify them to use the traditional lifters? Is it even possible to retrofit them?
kidturbo
Piston Tester
Jul 21, 2010
2,804
1,804
www.marinemods.us
Then fix the holes in the main bearing bores and good to go..
I passed on opertunity to do one cause of those two issues. Would like to do a new 6.7L Powerstroke if anyone interested. The reverse flow heads lends itself to quicker builds and less $$ in custom marine exhaust. No up pipes to condend with.
kidturbo
Piston Tester
Jul 21, 2010
2,804
1,804
www.marinemods.us
If these gold plated head studs purchased from Brad solve the head lifting issues, then gonna stick with LML platform.
I couldn't get anyone to come magnaflux the deck on #2. Ain't tearing it down further. It's go or blow one last time. If fails again, be pretty much certain that block has issues..
4,846
1,894
I wish those bad boys were cheaper, and I charged you my cost!
I love ARP but god damn are they expensive for 625s.
