Logged boost vs mechanical boost.
darkness
1,564
597
vegas
I recently was able to hook up my mechanical boost gauge. It reads 50% higher boost than what my cts3 gauge reads thru the whole range. Cts3 gauge reads what the tune is commanding. Mechanical gauge was checked for accuracy. I’m at a loss of what could be wrong. MAP sensor? Seems it would follow the tune if it was bad.
13,873
975
Is your CTS3 gauge an add on EAS device or is it reading the stock MAP sensor?
13,873
975
Have you verified the CTS reads the same as a scan tool or other datalogging system like EFILive?
darkness
1,564
597
vegas
I don’t have an obd2 splitter to do that, but could check certain areas I know what the cts3 reads. I know for a fact at max boost, the cts3 was reading what the tune was calling for. I was operating on boost map b and my max boost is 37psi. Boost was 24 on the cts3 and baro was at 13. And the mechanical gauge was 35psi.
3,113
37 - 24 = 13
Baro reads 13
Looks good
37 will be psig
24 is psia
13 is psia
34 looks like psig which is only 2 psi off the 37 psig. Might be a small error in either or both gauges/sensors. Nothing to worry about
darkness
1,564
597
vegas
Ok, I have a log. My computer is a pain in the ass so I have some pics instead of zip files. The boost numbers on the cts3 which read in psig, are the same as what my efilive log reads after the math (psia). All these numbers all point to everything works correctly…cts3 and MAP sensor. I verified the mechanical gauge also works in 5 psi increments on the regulator on my compressor. For reference, the original cts on my ‘02 and the mechanical gauge follow each other. I just don’t understand why the mechanical gauge reads 50% higher across the whole table than both the cts3 and efilive log.
darkness
1,564
597
vegas
I will say the few psi the log reads different from the table could be I haven’t learned the vane table to the new boost numbers. Boost seemed low so I added 20% from cruising rpm area to 3600.
