First Diesel - Frame Off and Full Built LBZ
HostileGarage
Learning as I go
Jun 9, 2026
Oregon
Well, hello all.
As the title states, this is my first Diesel. I waited way too long to come to the dark side, I was too busy messing around with combustion engines.
I've got a 2007 Sierra 2500HD Classic, CCSB getting a Fully Built motor mated up to a DDP Stage-2 Trans, S&S 100% Overs, 10mm CP3, the whole kit and kaboodle.
I've been lurking here for awhile, just soaking up information and learning. I decided it was finally time to make an account and join the process.
You can look me up on YouTube under "Hostile Garage" if you like.
Just a disclaimer, I don't know what I'm doing. lol
Backstory: Purchased this truck in May of 2024 with 172k. I had gotten some parts together to install in Spring of 2025, at the time I was doing a 'preventative' headgasket job. Basically, headgaskets up, I wanted to overhaul. If you know me, you'd know if I plan on having a rig for a long time and am unsure of its mechanical maintenence history; I'll get some of the big shit knocked out for reliability sake before anything becomes a problem. I also had an HSP Piping kit and 66mm VGT Turbo to toss on.
I'm glad I did.
Once we started digging into it, we found all sorts of shit. Injectors ended up being seized, so I went with 100% and a 10mm CP3. Which means I had to get a built block... which means I needed a built Trans. So, that's the route I went. In transferring Oil pump over from old motor to new motor (which is literally nearly the only thing that got transferred) we saw that both the Crank and Cam Gear dowels were both on the edge of letting go.
With the way the build went, I've recently decided to yeet the HSP Kit from the plan, and go with a big single S400 kit from DP Customs. Since I already have the HSP kit, I'll use whatever parts I need that the DP Customs kit doesn't include and sell the rest.
So, now its time to nail down a turbo and tuner. Engine and Trans are currently in the process of going back in the frame (Cab and Bed are off). Currently leaning towards an S467.7, with the 87mm turbine, just trying to decide on a .90 or 1.0 exhaust housing. Truck will be a daily driver, cross-country trekker, trailer puller, workhorse, with the occasional trip down the dragstrip or a sledpull at local events. I want to keep the towing manners reasonable while being able to have as much fun as possible when I'm not towing. 🤟 I figure I've got a motor and Trans that should reliably make 1000hp. I figure I've got fuel for about 800, which is why I was leaning with the 67 instead of the 72 (and for towing reasons). Any input is appreciated if you have experience with either.
Attached is a photo from a few weeks ago, prior to the motor going in.
3,473
Welcome to DD.
You are welcome to start a thread in the Builds section detailing your continuing mishaps and triumphs. We've all been there. :ROFLMAO:
LB7StillAlive
57
Arizona
That frame does look on-point, good work. Folks on here will have better knowledge than myself, but I have 467.7/83 with a .90 aspect ratio. I enjoy the drivability and sneaker tone it provides.
I haven’t towed anything heavy, but pulling 3,000lbs on some decent grades in heat, It seemed to perform just fine. Lived around 12-18lbs of boost at 75 and never really got hotter than 1100 degrees, when accelerating to pass I’d hit 1300 degrees. This was in 98 degree heat.
Again I don’t have a ton of experience with other setups, but my spooling begins around 1800rpms and peaks around 2700rpms. So I feel the .90 A/R works well. It does lag a bit when it bogs down in a gear, say when I’m leisurely putting along at 1500rpms.
Hope that’s helpful.
LB7StillAlive
57
Arizona
Passing wisdom on, many will let you know to pick a solid torque converter, the compatibility of the stall rating in relation to your desired use makes a difference.
4,822
1,865
Well, hello all.
I'm glad I did.
You did not need a built block to run 100% injectors, 10mm CP3, and a drop-in VGT but it also doesn't hurt. The dowels is the more concerning part than the fuel/air mentioned.
Personally, a 467/87 is a charger that offers no real gains over a 467/83 unless you're running compounds without a gate. Personally, I'd run a 6775G/0.95 T4 from Pulsar with a 6782G/0.95 T4 as my second choice. The 6775G is essentially a ball bearing Garrett clone 467/83 and the 6782G is the 467/87 version. You've got a billet gated pedestal so you can be greedy on the turbine side a little more than others can.
If you're dead set on a journal bearing S400, I would go S467/83/0.90.
How heavy are you planning to tow? If you tow often and heavy (15k+) I don't think you'll be overly happy with the towing performance compared to a quality drop-in VGT. People often underestimate the power of their turbine brake and truly how responsive a quality VGT is.
What converter is in your trans now? This plays a pretty big part in turbo selection unless you're going to have it restalled to match your new direction.
God damn that's a good looking chassis!
