New lml engine build, no fuel rail pressure
Toxic
99
31
Mansfield, OH
If you got no injector signal. I'd verify your cam signal is good and in sync with the crank signal. The ECM won't fire the injectors without a CAM signal unless the engine is already running and it looses the CAM signal
I believe it has good cam and crank signals.
3,147
On the last video, can't see which one os actual and which one is commanded fuel rail pressure. But if the lower one is actual then you aren't building pressure. Lost prime or lift pump isn't working if you have one
And fist video, not sure but I'm not seeing much of a CAM signal or count
Toxic
99
31
Mansfield, OH
Yes the bottom is actual fuel rail pressure. Lift pump works I’ve verified good flow to cp3, 8-9psi also. Lift pump goes straight to cp3. Might try a cam sensor then, pretty cheap.
3,147
If that is correct, you aren't building fuel pressure. It will never start with it that low
13,881
990
Did you ever check to make sure the regulator on the rail isn't dumping fuel back into the return while cranking? That's usually what I see is the main problem when the LML trucks aren't building rail pressure. It is easy to get the wrong connector hooked up to that regulator as there are 3 in close proximity that will fit. You should be able to unhook the hose from the nipple on the rail, pinch that hose closed, and run second hose from the nipple to a bottle. You should not see any fuel in the bottle after cranking.
Toxic
99
31
Mansfield, OH
I pulled the line off yesterday and I’m pretty sure I had some fuel coming out when cranking. Tried to get a few videos to confirm but as soon as I’d start cranking my phone would fall over. Valve cover was wet though.
Toxic
99
31
Mansfield, OH
Replaced the fuel pressure regulator/relief valve in the driver side fuel rail with a brand new Bosch . I still get some fuel out of the rail return when cranking.
Toxic
99
31
Mansfield, OH
What color are the wires to the connector on both regulators?
Purple/white stripe and yellow on the rail regulator. Not at the truck rn but I think the pump is black and yellow. Off hand not sure on the pump, but I know 100% the purple/white and yellow is on the rail.
Was trying to verify power to the rail regulator the other day, think I got the pins spread open too much and not making connection, have a p2294 that immediately comes back after clearing now.
Have verified the cp3 pump is pumping also. Need to rule out injectors somehow.
Gonna borrow a harness from a buddy and only swap injector pins around for the alt fire cam and see what happens. If it works I’ll buy it from him.
Toxic
99
31
Mansfield, OH
I believe I might have some bad injectors. Taking the return lines off and cranking for 15s, I’m getting some fuel out of a few of them. From what I’m gathering anyways, there shouldn’t be any.
