Rear pinion seal
68ss
158
80
Brooklet, Ga
So I replaced this seal about 4 thousand miles ago with I think a yukon gear set. What would cause the inner seal to do this?
3,930
829
Did you assemble it correctly? Looks like the wear sleeve is in front of the entire seal? Why was it taken apart, a leak? I did have just last week a National seal leaked between the steel and rubber joint, didn't even make it down the road
68ss
158
80
Brooklet, Ga
can you explain more? I reinstalled it the same way as it came out
3,930
829
Well idk, now I'm confused. I looked up the part # you have in the picture and I'm not sure how that's supposed to work.
I've always used the two piece setup that you drive a wear sleeve onto the yoke and a standard type pinion seal into the housing.
Almost looks like the seal was spinning in the bore, which doesnt happen. Does it?
That was my thought too. That's why I asked if he lubed it. If it stuck to the pinion shaft, it would turn the whole seal and tear out somewhere.
My 08 that I did didn't have a wear sleeve. Just right onto the pinion shaft
68ss
158
80
Brooklet, Ga
I think I figured out what I done wrong. I did not set the sleeve on the yoke first. I put the sleeve. The seal and then installed the yoke. I think it was not installed far enough on the yoke. I did install a gm seal this time but I do think this is totally on me
