Parking brake mechanism issue? DRW 3500 Won't take up slack.
Samisunjp
Sep 5, 2025
North Carolina
Hey all,
Troubleshooting my parking brake on my 3500 DRW. I'm not sure if my pedal is functioning correctly. When depressing the pedal it is not taking up slack as you depress the pedal consistently. The video below I took and shows what I am talking about. The silver wheel doesnt start tackingup the slack on the parking brake cable until the pedal is almost at the floor. Is there a way to adjust this?
1,456
If you maxed the shoes out in the wheel hub, 1. you won't be able to spin the tires and it will be hard to drive the truck.
2. the parking cables that run along the frame should be tight with little to no flex in them. Do the arms on the backing plate move that the cables are hooked too?
3. If you can move the truck as if it's not applied your parking brake pads are shot. you will need inner wheel seals as you have to pull the hub to gain access to the parking brake assembly.
I set my stuff up that the parking brake applies within first 2" of pedal travel.
1,456
Thats what is confusing, the cable is not being moved at all by the pedal in the first 2" of pedal travel.
Sounds like cables are rusted in the sheath and most likely the parking pads are smoked..
Check the brake lever at the wheel hub, when released, they should be angled forward. Should be close to ~2" between the lever and cable sheath mount when released
Samisunjp
Sep 5, 2025
North Carolina
I will be sure to check this tomorrow to see what is up
Ron Nielson
926
231
Berryton, KS
Maybe some help here
  • Parking Brake Adjustment (Disc Brake) .pdf
  • Park Brake System Diagnosis.pdf
  • Park Brake Cable Adjuster Disabling.pdf
  • Parking Brake Cable Adjuster Enabling.pdf
Ron Nielson
926
231
Berryton, KS
I can't see or test your truck from here, unless you are in Phoenix. The best I can do is to provide information.
Do you live where they salt the roads? If so, probably rust and corrosion is a big part of your problem
Samisunjp
Sep 5, 2025
North Carolina
Hey so it has been a long whiule but life happens. So far for this issue I have replaced:
Parking brake pads
Rear Rotors
All 3 parking brake cables
The pedal assembly itself
I can feel the parking brakes start to engage about the last inch or so of pedal travel but the most they hold are the truck in nuetral on a flat surface haha. As soon as it goes in gear not hold at all.
I'm completely stumped on this as at this point i feel like I have replaced everything possible.
Any more suggestions?
3,058
How have you have the star adjusters set? Of the pads and rotors are new, you should be able to adjust them to be snug when sliding the rotors on. If the rotors went on easy, they are too loose. You can, with some difficulty, adjust them through the ports on the inside
Samisunjp
Sep 5, 2025
North Carolina
Both sides are snug when putting rotors on and I am able to snug them up enough that I cannot turn them by hand. When I get the wheels back on the ground though it exhibits the behavior I described where they do not hold in drive or reverse.
3,058
Sounds like a stretched cable, even though you said you replaced it , or you didn't adjust the peddle
3,058
-Hold the park brake pedal in the FULL upward position.
-Pull rearward on the front park brake cable until the tension is released from the scribe or nail (1) installed through the holes in the pedal assembly.
-Remove the scribe or screwdriver (1).
-Slowly release the park brake cable until it returns to its original position.
-Release the park brake pedal.
-Lower the vehicle.
-Apply and release the park brake pedal to ensure that there is no binding or sticking.
