ok, got my truck bak last Friday, October 10, 2025 and the bill was $2512.60. they replaced the
1. body control module BCM
2. engine control module ECM
3. power control module module PCM
4. transmission control module TCM
5. transfercase encoder motor
12 hours labor
they lay blame on the ONSTAR module. said once the ONSTAR module was removed the buss line did the voltage on buss line return to normal
and only then communication was started to find other failed modules
got in the truck Friday paying bill, I was kinda ok with bill, and drivers seat wouldn't move any way but could see and hear seat motor try. went back inside and they took seat out, tested motor and said seat encoder was bad. passenger seat works fine.
is it possible that all these modules went bad after batteries went bad from grounds and which ground could have possible done the damage. im thinking the body ground under drivers door.
im ok will work done cause that's one of the few shops here and have good reputation. just wondering for myself.
thanks very much for the replies!!! rob
