2005 LLY -- need scanner suggestions
Jmac42
Jan 1, 2020
Hi all. I getting code P0046, I use a Fusion OBD2 scanner, it suggested Turbo vane solenoid and sensor as cause. I have pressure tested turbo inlet connections and repaired leaks. Im thinking about a bidirectional scanner but their are to many choices good and bad, what are good choices for a DIY guy?
Thanks Jack
Welcome
Personally, I like the V2/V3 from EFI live
Others will have recommendations for a snap on, Autel, Tech2, etc
3,593
Moved to Tuning/logging section.
There's always the Chinese Tech 2 option. Have you looked into the OBD dongle/phone app combos out there?
