Q - if this test ends up a dead end, what the heck could this problem possibly be? What are we missing here?
Sorry pretty new at electrical, this is the meter I’m using which setting do I need to be on?Lower the setting on the meter for a higher and more accurate reading
Try 200 uH
What do you get with the other settings?200 uH is the setting I was using to get those readings
Does it do the same right on the injector or just through the harness?So I was mistaken. When I took the reading this morning I was using the 2mH scale. When set to 200uH sometimes i get no reading and sometimes it jumpas all over the place up to 190. Not sure if this a fault of the meter or what. It is happening at all injectors. Can't get the reader to take an accurate measurement.
With the codes you have, it's unlikely. The ECM only sends on signals for each injector, crank signal and CANBus communication to the FICM. If there is a bad injector/harness the FICM is what sends the code to the ECM. The ECM doesn't know otherwiseAny chance of the ECU/PCM having some sort of issue?
Thats the odd thing. When I get it put together and running, it runs very rough, and with the cts3 and cts2 I have neither will display balace rates. Only shows 0 for all injectors.With the codes you have, it's unlikely. The ECM only sends on signals for each injector, crank signal and CANBus communication to the FICM. If there is a bad injector/harness the FICM is what sends the code to the ECM. The ECM doesn't know otherwise
When you do get the engine running. What do the balance rates look like?
I thought I connected all grounds back where they need to be. Tracking there are grounds passenger side below the head on the block, drivers side same location and one from the firewall to the back of the driver side head. Maybe I’m missing one?Can this be a ground issue? Are you sure you put all the grounds back after the head gaskets? Passenger side rear of the head?
I was mistaken the ground I am thinking of is driver side back of the head. I did not see one for the passenger side head.Can this be a ground issue? Are you sure you put all the grounds back after the head gaskets? Passenger side rear of the head?
