'01 3500 LB7 P0202 P0203 P0205 P0208 P1262 LB7 Issue after head gasket replacement
Samisunjp
North Carolina
Okay, so to update this thread in case anyone comes across it later looking to try to solve these codes.
Truck runs! No codes.
I put it all back together and I’m leaning towards what 2004LB7 said, a loose, or not tight enough nut on the injector harness under the valve cover.
Here is everything I have done or changed:
Rebuilt FICM (Had two working and both threw codes so don't believe it was this)
New engine wiring harness. (old one tested fine with no breaks on any wires so it wasn’t this)
New fuel filter housing (old one was working fine without leaks, only changed this because I was doing head gaskets)
Re-checked all grounds (Didn’t change anything with them before putting it back together so don't believe it was this either)
Checked ohms and inductance at all injectors (they were all within spec)
Only thing I can think of was a loose nut on one injector itself.
No codes and can now see balance rates without issue.
Going to do some test drives tomorrow to make sure everything truly is good. I will update tomorrow.
Thanks to everyone for all of their input and help.
JMK777
16's, but i keep em clean
Mar 20, 2008
1,437
5
Moss Beach
How is the truck running today? Did you have any issues after you fix the problem?
I’m going through the exact same thing you did . I’m on my second wiring harness , I ohm everything and everything specs out . but I have one bank of injectors that is shut off and the balance rates on those injectors are all +12. The truck ran fine before I pulled it apart to fix a leaking cup.
JMK777
Mar 20, 2008
1,437
5
Moss Beach
This was a great thread. Just got my truck running again .Pulled the valve covers pulled all the wiring cleaned everything re-torqued the wires back to the injectors (18 inch pounds)and she fires right up. Now we’ll see how well lapping the cups into the cup seats will work.
3,148
If you're going through the work of lapping the cup seats, I would have just gone with threaded cups
Samisunjp
North Carolina
Yep runs good but looks like I need to do injectors now! Although that is unrelated. Basically yes it came down to needing to make sure all the wires are properly seated.
