10-4, ill figure out a way then, just dont wanna keep flogging it on the banana rod tune, hopefully I can log it and get some usable data. I remember looking down during the pass and remembering right around 100 was when it flat lined.I’d be checking that. We need to make sure supply is consistent. Dont throw a bigger pump at it yet, i cant see you taxing that 165 yet.
Bad sensor as in a fuel rail pressure sensor or the harness to it?You read it right, both actual and desired dropped off. I would look at all the tables that would limit fuel pressure. Then log those tables and see what’s happening. Could be a bad sensor or wiring problem.
