Thank you but we were able to get it to flash.Worst case pull the module and send it to me. If he wants to save the VIN license send the flashing device as well.
I can attempt a bench flash via SPS and then put his file into it.
Unhooked the batteries overnight.
Started with the stock tune the next day. First attempt failed with a $0101 EFILive error.
Tried stock tune again, it loaded.
Then flashed in the DSP5 tune from Rob, back in 16 when I did the conversion.
The DSP5 tune loaded as well.
No effect on functionality of the truck. It's still dead.
Replaced Cam position sensor.
Crank position sensor ohms out fine.
Currently looking at replacing the ECM as the injectors are not getting any signal.
He's in communication with a ECM repair place, they're telling him it sounds like the theft deterrent in the BCM, not ECM.
No codes, nothing. I hate just throwing parts, but I'm six hours away from the truck and at a loss to really help him.
