Background: 2005 LLY bought it a few years ago with 150K miles, truck now has 171k.
Mods:
LBZ intake elbow
5" exhaust
DSP5 tuning
Built Trans & goerend DK converter
When I bought the truck it was winter time and on the drive back from AZ with it, the truck never would warm up fully. After I got it home, I put new GM 180° and 185° thermostats in the truck which fixed the running cool issue.
I've noticed recently driving the tuck on cooler days (below 60° F), the truck will run about 180-185° unless I get on it, then the temp will rise to about 190°-192° and cool back down once the load decreases. On hot days the truck will consistently run between 190° and 205° running empty or towing. I do not have any issues with the truck using coolant or the heat going in and out. Upper coolant hose stays pliable after driving the truck hard and letting it sit overnight.
I put a lift on the truck with 20x12's and 33" trail grapplers 2 years ago, and my fuel mileage has been 11-14 mpg regardless of how I drive the truck or what level I have the dsp5 set at. Tuning was done by a reputable tuner, so I do not think that is the issue as the truck got 13-18 mpg stock height with the factory pyo's and 245 michelins. I am not sure if the converter is contributing more to my fuel mileage woes now that there's more rolling mass. The truck is a toy at this point so while I am not that concerned about the fuel mileage, it does seem odd it dropped off so much.
The balance rates seem reasonable based on the calculated fuel rate and the truck holds rail pressure.
Am I at the beginning stages of the truck needing head gaskets and/or injectors/CP3 or do I just need to do thermostats again and I have some other issue that is hurting my mileage?
Mods:
LBZ intake elbow
5" exhaust
DSP5 tuning
