LB7 LML Allison 1000 conversion & swap
Lost0187
13
North Ga
He hasn’t really gained anything other than complexity when it comes to the electronic line pressure control over using an 06-10 6 speed trans where it’s all mechanical. But as he’s talking about a solenoid blocker/epc fooler, he’s not utilizing the electronic pressure controls anyway and running it full pressure like the earlier ones do anyway.
Internals are pretty much the same with a different valve body. Kind of a pointless swap for most people imo. Unless you have a clapped out 5 speed and an lml trans just laying around.
A lot of the gen 3 Allison internals are quite different it’s not only just a changed valve body. But to be honestly the gen 2 set up is probably the strongest with the gen 3 being the most efficient. Now most of the gen 2 stuff will back service to the gen 1 units they just increased the TQ capacity as the trucks out put more power. In turn they had to make sure the hard parts got stronger as well. But if you do some research you will find a lot of internal parts from gen 3 won’t back service with the gen 1 and 2.
Lost0187
13
North Ga
Truck actually left again last night for another Florida trip it has never left my little brother stranded and has been just an extremely reliable vehicle. The last 2 weeks have been busy trying to build his new farrier rig since STONE WELL didn’t have any available. Here are some pics was built from scratch he left in a hurry last night but I’ll have him send some of the more finished pics. The set up will be paint to match once he come back up to North Ga. All in all turned out great seeming as these rigs cost 30k but it’s nice when you can build them your self to your spec and needs.
Lost0187
13
North Ga
So with the trans also you don’t have to run a blocker my little brother wanted to you would basically modulate it like the 04-10 do with the G solenoid the only difference and one pointed out the 11 and up is a variable resistance solenoid meaning you can open and close it with PWM vs the 04-10 being a simple on off solenoid basically the same as the SSC-E. In the older trucks the G was added to reduce line at Idle and also on shifts so it wants so noisy (on L18) cause let’s face it with a Duramax you can’t hear pump noise over the engine at idle.
Lost0187
13
North Ga
Here is the TCM installed in the truck we moved it to behind the fuse box no changes needed wire harness moved perfectly. As you’ll notice under the hood the extra relay box against the battery this truck has a true Escalade ESV platinum swap from harness to interior. We integrated it to the a 2004 LB7 engine / transmission harness. Everything functions tire pressures etc. the one thing I’m not sure if we will ever get around to is the traction control provisions we are using the 05 esv abs module installed to the K2500 with the independent wheel speeds. There was some playing to get it all correct but truck has been great. Was bought a 2002 but has been updated to a 2003-2006 setup. Also I have the dual fans from the 05 Escalade donor eventually I will install them and wire them up I’ll either use a PWM from derale or a similar controller.
Lost0187
13
North Ga
Here are some pics of the 2011 LML vs the 2002 gen 1 Allison 1000 the LML is on the bench the LB7 is on the stand in the first few pics then on the pallet after. Notice the case on the LML has some extra webbing with the valve body removed vs the smooth cast from the gen 1. Also there is webbing behind the PTO covers. Not sure if the gen 2 had the extra webbing or the smooth cast can’t remember the last time I went into one. Also originally I was running my 6 speed conversion in the LB7 unit but the trans was very tired and C4 was starting to fail prior so we thought why not just see if we could use the LML unit and we made it work.
4,846
1,894
Also I’m using the factory TCM 01-05 with my own custom tuning and yes I have 1-6 this is my little brothers truck I have done quite a few some opt for just valve body swaps others to fully replace the transmission especially if it’s worn. Either way the goal is the same to get that extra gear and the .67 ratio and drop the rpm’s while cruising as well as get a lot better fuel milage depending on how you tune the engine side. This truck gets about 27 mpg and has pulled some heavy loads for a 2500. You can opt for a 2006-2010 valve body or a 2011-2019 it doesn’t matter I can make it work. I just like making older things new and helping out to achieve things that the common programmer / mechanic would say can’t be done it can always be done with time and patience.
The easiest way if you swap to a newer transmission is get a 2006-2007 LBZ unit nothing has to be changed basically just bolt it up do some wiring internally get a custom tune and enjoy.
2nd option VB swap / wiring Tune and enjoy.
What wiring did you have to do, swapping the pigtails for A trim/B trim/TCC? Or possibly repin the 06-10 harness?
If I recall correctly the resistance values of the trim solenoids or the TCC solenoid is different than the 01-05 unit.
Lennart
Not from here !
Aug 10, 2006
315
Detmold, Germany
I am looking into upgrading my LLY to a 6-speed....to increase the top speed ;)
After reviewing the electrical differences between 05 and 06 VBs I am a little concerned the F Solenoid from the 06+ VBs will work sufficiently with the older TCM, as the TCM only outputs 100Hz, while the newer use 1kHz. The red connector solenoid will not like the 100Hz too much. While it will work, the pressures will be lower at 100Hz vs. 1kHz.
There is a good article on that: ARTICLE
Might be fine when running stock power levels, not sure how well it will work with higher hp trucks.
Swapping the cables to match the older TCM looks straight forward if you compare both schematics next to each other.
Not sure at the moment if the 06 VB will be the better choice over the 05 with the modifications SC did (which I am not familiar with except for the 2nd tube added). At least when mofifying my 05 VB I know that 1-5 will work as before, only tweaking of 6th needed.
At 4000 RPM, 5th gear, 3.73 rear end and stock sized wheels you can exceed 135 MPH. How much faster are you trying to go? Or are you just pulling our leg?
Lennart
Not from here !
Aug 10, 2006
315
Detmold, Germany
Can you spin a stock internals motor to 4000? Mine is limited at 3850. Was tring to find a new reason why the 6th gear is useful, the 30k miles my truck has after 20 years will not justify it by the saved fuel. Mainly cruising noise is also the reason I want to do it
Cruising noise is literally the only reason to do the conversion
4k RPM is easy with tuning
Lennydmaxguy
Just another diesel tech
Nov 8, 2023
130
74
Somewhere, USA :)
I can verify an 06 VB works fine in 01-05 trucks.
Cougar281
1,979
406
St Louis, MO
I can tell you a 06/07 VB being run as a 5-speed does some funky things, most noticably on coming to a stop. As the trim solenoids are the only ones that are different, pretty sure that's why.
Lost0187
13
North Ga
You guys can run pretty much any Allison 1000 6 speed valve body but depending on which one you use will depend on changes to calibration itself to get the best results.
Lennart
Not from here !
Aug 10, 2006
315
Detmold, Germany
Had my VB off the truck, bought a used LBZ VB, drilled 2 holes into my VB (put an M8 thread in one...in case something totally unexpected happens I can block it without removing the VB), added the 2nd tube. IMG_20250601_212730660.jpg
Took the truck for a ride, the 5 speeds are working as before, now to the tune file for the 6th gear.....
Lost0187
13
North Ga
How come you drilled a hole in the VB? If the VB was a LBZ one with the 2 fluid tubes you didn't need to modify it? Was this done to relieve pressure cause if you aren't careful you will have a leak in the valve body fluid chambers.
Lennart
Not from here !
Aug 10, 2006
315
Detmold, Germany
I drilled my LLY VB to add the second tube. The VB pictured is a 5-speed VB with the added tube. In order to allow the fluid to move it takes these two holes. Externally this is the same as Suncoast did, just don`t know if it takes any other mods inside the VB.
